Page not displaying correctly in Internet Explorere
Thread began 7/05/2009 4:31 pm by dncnkt | Last modified 7/06/2009 1:18 pm by dncnkt | 2338 views | 4 replies |
dncnkt
My Contact Us page has a very large space above Your Name when viewed in IE7. It displays correctly in Firefox and Safari. Please take a look and let me know if you have any ideas.
contactus.php
I'm also hoping someone can help with the "invisible" text which isn't invisible!
The text is visible because you are missing the spry .css and .js files in the header. Just copy them from the sample and they should be "invisible" again.
Justin Nemeth
I think the CSS needs to be updated to work like a standard 2 column layout. Within your #contentWrapper, you have right column that is floated. The left column div (which contains your form) should have a "margin-right: 330px" and shouldn't have a "width: 100%". Give that a try and see if that fixes it.
dncnkt
You were correct - there was a leftover rule that I had in there from the template that I used, which should have only been there if the right column wasn't there. Thanks.
I fixed the head section but now the CAPTCHA portion is broken. I'm a little frustrated! Should I just start with fresh files and upload everything again after styling?
dncnkt
Never mind! I found the error - Thanks for you help!!
