sagepay again
Hi
just setting up the payent gateway to use the sage pay simulator
I assume the gateway should be Sage Pay VSP Server
The vendor is the vendor name I set up
The server I assume I should set to testing??
IS this correct?
thanks
Ian
Hi
IS this correct?
thanks
Ian
yes, for the vendor, enter the vendor name you set up.
for the server, select testing to perform test transacts through the sage pay server. you will need to change that to live in order to place actual transactions.
