Security assist getting started wizard
Thread began 9/16/2009 5:35 pm by roywurgley382617 | Last modified 9/17/2009 5:24 pm by roywurgley382617 | 2668 views | 8 replies |
roywurgley382617
i am working through the getting started wizard from the rescourses page, but cannot seem to get the email forgot pw to work, everything else seems to be ok, i double checked my smtp port setting. i fill out the email address that is in db, but nothing happens, don't receive any email back with. Is there any other extensions I should be using to make this complete user registration. thx for your help
In some cases, if you fill in the From Display Name, the email will not be sent, try leaving that blank.
Have you set a redirect page for if look up passes and if look up fails? Which one are you redirected to?
check with the host to see if they can look into the SMTP server error logs to see why the email is not being relayed.
roywurgley382617
hello Jason,
ok this is for another site I am working on, that I need a complete registration, login, forgot password, logout.
registration works, info in db, can login no problem, but when I go to forgot email I am not receiving an email.
when I leave the email form blank, nothing happens
when I fill my email address in (one in db) the page redirects to login page, but still no email
Thx for your help
Sounds like you do not have a redirect page for if the lookup fails, but the redirect page if the lookup passes is the login page.
roywurgley382617
Jason,
Thx, when you say leave the "from display name blank", are you refering to in setting up with the wizzard? Also contacted my host and they are looking in to smtp logs, thx again
If you double click the Security Assist Email Password server behavior, there is a setting for the From Display name and the from address, Leave the from display name blank.
roywurgley382617
Jason,
ok getting closer, I am receiving mail now, I think it was with the host, did not change the display name thing. Now when received mail the pw is encrptyed, it is suppose to be 40 characters long. Also noticed there is an red ! mark next to update records(members) in the members_EmailPW.php, tried to fine out what thats about, but no luck, Thx again Roy
Double click email password server behavior. On the last step, you can configured ho the email is sent. by default it will send the password from the recordset. remove the password reference and click the Plus button to select the NewPW session variable which contains the unencrypted password.
Is the new password being store in the database correctly?
If so, ignore the red exclamation mark. That only means there *may* be a problem, if it is working correctly though, you can ignore it.
roywurgley382617
Jason,
ok it seems to be working pertty well, I found 4 lines of
<?php require_once('Connections/memberAdmin.php');?>
should only need 1, so I removed the 3, now the red ! mark is gone,
Ok I will pick up on this next week, off for the weekend, enjoy what time you have off, and thx again for everything, Roy
