DSN ? & Path
Thread began 2/12/2010 11:19 am by martin1028340912 | Last modified 2/12/2010 5:48 pm by Eric Mittman | 700 views | 1 replies |
martin1028340912
DSN ? & Path
I have an Access database that I need to pull the results from. I have setup a DSN connection with my host. How do I work locally with DataAssist?
Also, if my site is in the wwwroot with the host and my database is in the data folder shouldn't the path be data/mydatabase.mdb?
All other directions for using DataAssist makes sense to me but getting a connection is my problem. Any help here is appreciated.
To work locally and test you might want to have a local testing server. If you have it setup like this you can go to control panel > administrative tools > odbc and setup a new system DSN. When it is setup there you can then go into DW and in the db tab add a new DSN connection, then select the DSN from the list.
If your host has the DSN setup you should be able to specify your hosted site as the testing server and access the DSN in a similar fashion.
