Changing background color of side menu
Thread begun 2/18/2010 6:57 pm by rmcadams351257 | Last modified 3/03/2010 6:46 pm by scott395605 | 8508 views | 18 replies |
rmcadams351257
Hi;
I'm using Powerstore3 and I can't seem to find a way of changing the background color of the side menu. I would like to change it to black. Can anyone help?
Ron
in the spry_custom.css file, change the background-color property for the AccordionPanelTab class.
rmcadams351257
Thank you
Thanks for the help.
You guys are quick!
Ron
scott395605
Okay I've got all that, works great on hover but once the "button" is "open" it reverts back to default blue #3375A2... This happens in both Firefox and Safari if that makes a difference... Any guidance?
you also need to change the .AccordionFocused .AccordionPanelTab class in the spry_custom.css file, and the doHighlight script in the main.dwt.php template:
function doHighlighlight(div) {
div.setAttribute('style',"background-color:#3375A2; color: white; border-top:0px;");
div.style.cssText = "background-color:#3375A2; color: white; border-top:0px;";
scott395605
Changed all of them but still have the same results... This is driving me crazy...
You can see it at:
http://dkflatwoods.net/DK_Store/Products_Results.php
when I view source of your page, I do not see any changes made to the script code:
nor do I see any changes to the .AccordionFocused .AccordionPanelTab class in the spry_custom.css file.
It doesn't look like the changes are being uploaded to the server.
carleneBeta Tester
I asked the same question and am continuing on with my questions about this issue on this page: showthread.php?t=10734
Was given a more helpful answer - but it still isn't working. Am having the same problem with the color change not sticking.
scott395605
front-line fixer
I'm seeing this also on my source code, but when I open my Main.dwt.php and the spry_custom.css file the code is the correct color...
main.dwt.php
var lastHighlight = new Array();
div.setAttribute('style',"background-color:#7E9653; color: white; border-top:0px;");
div.style.cssText = "background-color:#7E9653; color: white; border-top:0px;";
var y = 0;
for (var x=0; x<lastHighlight.length; x++)
spry_custom.css
/* These selectors change the way messages look when the widget is in one of the error states.
* These classes set a default red border and color for the error text.
* The state class (e.g. .textfieldRequiredState) is applied on the top-level container for the widget,
* and this way only the specific error message can be shown by setting the display property to "inline".
.textfieldRequiredState .textfieldRequiredMsg,
.textfieldInvalidFormatState .textfieldInvalidFormatMsg,
.textfieldMinValueState .textfieldMinValueMsg,
.textfieldMaxValueState .textfieldMaxValueMsg,
.textfieldMinCharsState .textfieldMinCharsMsg,
.textfieldMaxCharsState .textfieldMaxCharsMsg,
.textareaRequiredState .textareaRequiredMsg,
.textareaMinCharsState .textareaMinCharsMsg,
.textareaMaxCharsState .textareaMaxCharsMsg,
.textfieldServerError,
.passwordRequiredState .passwordRequiredMsg,
.passwordMinCharsState .passwordMinCharsMsg,
.passwordMaxCharsState .passwordMaxCharsMsg,
.passwordInvalidStrengthState .passwordInvalidStrengthMsg,
.passwordCustomState .passwordCustomMsg,
.confirmRequiredState .confirmRequiredMsg,
.confirmInvalidState .confirmInvalidMsg,
.selectRequiredState .selectRequiredMsg,
.selectInvalidState .selectInvalidMsg
font-style: italic;
color: #CC3333;
border: none;
/* The next three group selectors control the way the core element (INPUT) looks like when the widget is in one of the states: * focus, required / invalid / minValue / maxValue / minChars / maxChars , valid
* There are two selectors for each state, to cover the two main usecases for the widget:
* - the widget id is placed on the top level container for the INPUT
* - the widget id is placed on the INPUT element itself (there are no error messages)
/* When the widget is in the valid state the INPUT has a green background applied on it. */
.textfieldValidState input, input.textfieldValidState,
.textareaValidState textarea, textarea.textareaValidState,
.passwordValidState input, input.passwordValidState,
.confirmValidState input, input.confirmValidState,
.selectValidState select, select.selectValidState
/* When the widget is in an invalid state the INPUT has a red background applied on it. */
input.textfieldRequiredState, .textfieldRequiredState input,
input.textfieldInvalidFormatState, .textfieldInvalidFormatState input,
input.textfieldMinValueState, .textfieldMinValueState input,
input.textfieldMaxValueState, .textfieldMaxValueState input,
input.textfieldMinCharsState, .textfieldMinCharsState input,
input.textfieldMaxCharsState, .textfieldMaxCharsState input,
textarea.textareaRequiredState, .textareaRequiredState textarea,
textarea.textareaMinCharsState, .textareaMinCharsState textarea,
textarea.textareaMaxCharsState, .textareaMaxCharsState textarea,
input.passwordRequiredState, .passwordRequiredState input,
input.passwordInvalidStrengthState, .passwordInvalidStrengthState input,
input.passwordMinCharsState, .passwordMinCharsState input,
input.passwordCustomState, .passwordCustomState input,
input.passwordMaxCharsState, .passwordMaxCharsState input,
input.confirmRequiredState, .confirmRequiredState input,
input.confirmInvalidState, .confirmInvalidState input,
select.selectRequiredState, .selectRequiredState select,
select.selectInvalidState, .selectInvalidState select
/* When the widget has received focus, the INPUT has a yellow background applied on it. */
.textfieldFocusState input, input.textfieldFocusState,
.passwordFocusState input, input.passwordFocusState,
.confirmFocusState input, input.confirmFocusState,
.selectFocusState select, select.selectFocusState
background-color: #FFFFCC;
/* This class applies only for a short period of time and changes the way the text in the textbox looks like.
* It applies only when the widget has character masking enabled and the user tries to type in an invalid character.
.textfieldFlashText input, input.textfieldFlashText,
.textareaFlashState textarea, textarea.textareaFlashState
color: red !important;
/* When the widget has the hint message on, the hint text can be styled differently than the user typed text. */
.textfieldHintState input, input.textfieldHintState,
textarea.textareaHintState, .textareaHintState textarea
/*color: red !important;*/
.Accordion {
border: solid 1px white;
overflow: hidden;
.AccordionPanelTab {
background-color: #eeeeee;
border: 0;
border-top: solid 1px white;
padding:10px;
.AccordionFocused .AccordionPanelOpen .AccordionPanelTab {
background-color: #7E9653;
.AccordionPanelOpen {
border: 1px solid #7E9653;
.AccordionPanelOpen .AccordionPanelOpen {
border: 0;
.AccordionFocused .AccordionPanelTab {
.AccordionFocused .AccordionPanelTabHover {
color: #FFF;
color: #FFF;
.AccordionPanelOpen .AccordionPanelTabHover {
color: #FFF;
.AccordionFocused .AccordionPanelOpen .AccordionPanelTabHover {
color: #FFF;
For some reason after I upload it the linked pages to the template do not seem to refresh with the new code...
1) To be able to make modifications to the template using Dreamweaver, you must extract the power stoer files to the root of your dreamweaver site.
double check that the power store files are at the root of your dreamweaver site.
2) When you modify the template, make sure that none of the other files are open in Dreamweaver.
3) When you save your changes, you should be prompted to update files that are based on the template. If you are not prompted to update files, you can force this by going to Modify -> Templates -> Update Pages.
4) After updating all of the pages, you must upload the entire site to your remote host.
