Support here is a disgrace - Update Multiple Records is a failure
Thread begun 2/24/2010 1:37 am by Jaffa | Last modified 2/25/2010 4:04 pm by Jaffa | 7020 views | 16 replies |
Jaffa
Update Multiple Records only updating last record
Looks like Web Assist is dead in the water, No response, no help. Why don't you hire more support help or do something here to answer questions. After joining your monthly subscriptions I feel i have been taken for a ride with the buggy half implemented extensions that are being developed.
Here's the code that your DATAASSIST Update Multi Records produces. It simply does not work at all. How can this issue still go unanswed all this time.
<?php require_once('../Connections/Database.php'); ?>
<?php require_once("../WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
mysql_select_db($database_Database, $Database);
$query_rsFish = "SELECT TID, NAME, ENABLED FROM TropicalFish WHERE ENABLED = 'Yes' ORDER BY NAME ASC";
$rsFish = mysql_query($query_rsFish, $Database) or die(mysql_error());
$row_rsFish = mysql_fetch_assoc($rsFish);
$totalRows_rsFish = mysql_num_rows($rsFish);?>
// WA DataAssist Multiple Updates
if ($_SERVER["REQUEST_METHOD"] == "POST") // Trigger
$WA_loopedIDField = array("WADA_RepeatID_TID");
$WA_connection = $Database;
$WA_table = "TropicalFish";
$WA_redirectURL = "TropicalFish_Results-Enabled.php";
$WA_keepQueryString = false;
$WA_indexField = "TID";
$WA_fieldNamesStr = "NAME|ENABLED";
$WA_columnTypesStr = "',none,''|',none,''";
$WA_connectionDB = $database_Database;
$WA_multipleUpdateCounter = 0;
while (WA_AB_checkLoopedFieldsNotBlank($WA_loopedIDField, $WA_multipleUpdateCounter)) {
$WA_fieldValuesStr = "".WA_AB_getLoopedFieldValue("Name", $WA_multipleUpdateCounter) ."" . "|" . "".WA_AB_getLoopedFieldValue("Enabled", $WA_multipleUpdateCounter) ."";
$WA_where_fieldValuesStr = WA_AB_getLoopedFieldValue($WA_loopedIDField[0], $WA_multipleUpdateCounter);
$WA_where_columnTypesStr = "none,none,NULL";
$WA_where_comparisonStr = "=";
$WA_where_fieldNames = explode("|", $WA_indexField);
$WA_where_fieldValues = explode("|", $WA_where_fieldValuesStr);
$WA_where_columns = explode("|", $WA_where_columnTypesStr);
$WA_where_comparisons = explode("|", $WA_where_comparisonStr);
$updateParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WhereObj = WA_AB_generateWhereClause($WA_where_fieldNames, $WA_where_columns, $WA_where_fieldValues, $WA_where_comparisons );
$WA_Sql = "UPDATE `" . $WA_table . "` SET " . $updateParamsObj->WA_setValues . " WHERE " . $WhereObj->sqlWhereClause . "";
$WA_multipleUpdateCounter++;
if ($WA_redirectURL != "") {
// RepeatSelectionCounter_1 Initialization
$RepeatSelectionCounter_1 = 0;
$RepeatSelectionCounterBasedLooping_1 = false;
$RepeatSelectionCounter_1_Iterations = "1";
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<title>Test</title>
</head>
<body>
<form name="form1" method="post" action="">
// RepeatSelectionCounter_1 Begin Loop
$RepeatSelectionCounter_1_IterationsRemaining = $RepeatSelectionCounter_1_Iterations;
while($RepeatSelectionCounter_1_IterationsRemaining--){
if($RepeatSelectionCounterBasedLooping_1 || $row_rsFish){
<table width="40%" border="0" cellspacing="0" cellpadding="5">
<tr>
<th>Name</th>
<th>Status</th>
</tr>
<?php do { ?>
<tr>
<td><label>
<input type="hidden" name="WADA_RepeatID_TID_<?php echo $RepeatSelectionCounter_1; ?>" id="WADA_RepeatID_TID_<?php echo $RepeatSelectionCounter_1; ?>" value="<?php echo $row_rsFish["TID"]; ?>" />
<input name="Name_<?php echo $RepeatSelectionCounter_1; ?>" type="text" id="Name_<?php echo $RepeatSelectionCounter_1; ?>" value="<?php echo $row_rsFish['NAME']; ?>">
<input name="ID_<?php echo $RepeatSelectionCounter_1; ?>" type="hidden" id="ID_<?php echo $RepeatSelectionCounter_1; ?>" value="<?php echo $row_rsFish['TID']; ?>">
</label></td>
<td><label>
<input name="Enabled_<?php echo $RepeatSelectionCounter_1; ?>" type="text" id="Enabled_<?php echo $RepeatSelectionCounter_1; ?>" value="<?php echo $row_rsFish['ENABLED']; ?>">
</label></td>
</tr>
<?php } while ($row_rsFish = mysql_fetch_assoc($rsFish)); ?>
</table>
} // RepeatSelectionCounter_1 Begin Alternate Content
else{
<td>No records match your request.</td>
<?php } // RepeatSelectionCounter_1 End Alternate Content
if(!$RepeatSelectionCounterBasedLooping_1 && $RepeatSelectionCounter_1_IterationsRemaining != 0){
if(!$row_rsFish && $RepeatSelectionCounter_1_Iterations == -1){$RepeatSelectionCounter_1_IterationsRemaining = 0;}
$RepeatSelectionCounter_1++;
} // RepeatSelectionCounter_1 End Loop
<p>
<label>
<input type="submit" name="Update" id="Update" value="Submit">
</label>
</p>
</form>
</body>
</html>
mysql_free_result($rsFish);
I have not touched this code at all so it's fair to say it's not end user error, I would appreciate your attention to this matter ASAP or at least have the courtesy to answer any of my posts or provide a solution to your half baked extension called Data Assist
What do you mean by "simply doesn't work at all"?
Do you get errors? Does it redirect after you submit?
Do the repeated records show in the form correctly and just the update doesn't work? Do you have a URL where I can see the problem live?
Please describe your problem in detail instead of your personal opinions about the quaility of work I provide. If you were as precise about describing the problem as you are in bad-mouthing our team, it would be a more constructive approach to actually solving the problem.
Office Guy-172461
I'd also like to point out that your 3 requests for help in multiple threads were made outside of normal support hours. Australia is in a different time zone.
10 Tips for getting quick help from a support forum
http://www.ipvac.com/kb/entry/149/
Jaffa
OK the update mutiple record behaviour after spending almost 13 hours on it looks to only update the last record. There have been mutiple threads on this issue and no solutions.
I have attached my php page here.
Jaffa
can someone please help here! 2 days now.
Jaffa
Still waiting for a fix to this problem
Dave BuchholzBeta Tester
The WA guys are in bed, you have to bear in mind that they work Pacific Standard Time which in 19 hours behind you approx
I have attached a revised version of your page which will work, the basic issue you have is that the repeat selection iteration code needs to be inside the standard DW loop
Jaffa
Dave you are a gem.
Thanxs so much for fixing the code and explaining what the problem was.
Cheers mate!
No worries, just bear in mind when complaining about support in the future that your working day does not coincide with WA's apart from a small window so please be patient it's not that people don't want to help you it's that their probably in bed !
Jaffa
One question I just ran the wizard again and got the same code that i attached, Is there a known bug in this feature? The attachment you sent worked fine but it certainly does not reflect what DA creates.
