How do I save the total number of items in a cart into database?
Thread begun 2/24/2010 6:12 am by info4753 | Last modified 3/02/2010 11:09 am by Dani Chankhour | 3270 views | 5 replies |
info4753
Maybe I missed the option but I can't find way to save the total number of items in a cart into the database (summary). How do I do this?
It is not something that you missed, it is not a binding that is available from the eCart object. You can get this info into your db by using this for the value of the column:
<?php echo $eCart1->TotalColumn("Quantity"); ?>
You will need to adjust the eCart1 part to be the name of your cart.
Dani Chankhour
Instead of storing the number of items in the order, you could modify the query that is going to display the number of items by using the Count() function which will return the number rows.
Here is query example:
SELECT t1.OrderID, t2.DetailOrderID, COUNT(t1.OrderID) as tot
FROM ps3_orders as t1 INNER JOIN ps3_orderdetails as t2 on t1.OrderID = t2.DetailOrderID WHERE t1.OrderID = 1
Let me know if you have additional questions.
info4753
Thanks for your fast replies.
Due to the fact that I want to show the total number of items in a order history, the query solution seems to be the better one.
dave315749
how do i show the total in the cart on the home page of my site?
what files do i have to include from the ecart to show how many items and what is the total amount of money in the shopping cart?
Dani Chankhour
Depending on what the name of your cart, you will have to add these lines of code to the top of your page:
//WA eCart Include
require_once("WA_eCart/eCart1_PHP.php");
$eCart1->GetContent();
in this case my cart is called eCart1.
