Adding thumbnails with image upload
Thread begun 3/01/2010 3:21 pm by koneill385535 | Last modified 5/20/2010 10:38 pm by Jimmy Wu | 8444 views | 24 replies |
koneill385535
I followed this tutorial for uploading detail images and thumbnails at the same time in my insert page with DataAssist:
digital_file_pro_resize_images_ht.pdf
I already had an image upload button, but I wanted to change the server behavior to include a thumbnail. I tried editing the server behavior, but when I tested it out, it didn't provide the thumbnails in the results page. How do I get the results page to show a thumbnail without asking the user to upload two separate images?
Ian
Store the name of the thumbnail in a separate field, and call that image on the thumbnail page.
koneill385535
How do I store it in a separate field if I want it to simultaneously upload the image and the thumbnail? I've got it so it saves it in two separate folders with different sizes, I just don't know how to access the photo. I am attaching what I did with the Digital File Pro Upload Wizard.
Dani Chankhour
You can just use the same image tag you have for the main image and just update the source attribute to use your thumbs folder instead:
<img src="thumgfolder/image.jpg" />
If you post your current image tag i can tell you what you need to change exactly.
koneill385535
OK, I changed it around a little bit to where I thought it would work. It isn't quite right though. Here is my image tag:
images/product_thumb/<?php echo $row_WADAproducts["ProductImage"]; ?>
I am uploading the rough draft of the site so you can take a look at the code. I just uploaded the new insert and results page so you can try it out and look at the code.
I also am attaching what the result looks like.
koneill385535
Oops, and the insert and results pages are these:
products_Insert.php
products_Results.php
Dani Chankhour
OK, i think what you need to do is this:
images/product_thumb/<?php echo str_replace("detail", "thumb", $row_WADAproducts["ProductImage"]); ?>
Since the field in your database it probably named image_detail.jpg but you want o display image_thumb.jpg. So the above replacement will replace detail with thumb.
koneill385535
Hmm... That didn't seem to work. It just brings up a missing image thing.
Dani Chankhour
I'm not able to view your product results page because it requires a log in. But what you can do is view the source of your image tag and see what is the resulting url that is being generated in the source attribute. and then we can compare it to what it actually needs to be.
please post back with the source of the <img> tag and what is the url needs to be to view the page.
koneill385535
Ok, when I click on the picture in Dreamweaver, the field labeled src is this:
I'm not sure what it should be, or exactly where and what name the thumbnail is. I took off the restrict access behavior, so you can access the site now:
products_results.php
