Applying Validation to CSS Elements
Thread begun 3/02/2010 8:38 am by bill181745 | Last modified 3/02/2010 10:53 am by Jason Byrnes | 1485 views | 1 replies |
bill181745
In the example you have in "How to apply CSS styles to form elements with Validation Toolkit" you are using tables and it works great with tables, I am referring to the red background color for the form field using class of "fail".
I am not using tables but using CSS for the entire form. How would I apply the background color when the validation kicks in to the element that already has a class. I have tried applying the style of the element using the ID and then using the class="fail" but that doesn't seem to work, I might be looking to hard.
thanks
Bill
you can assign two classes to an element by putting a space between each class name:
class="classOne classTwo"
or if you use an ID, make sure to change the css from a class:
.fail {}
to an ID:
#fail{}
