Not receiving the email
Thread begun 3/11/2010 4:03 pm by jball9299 | Last modified 3/12/2010 1:25 pm by Eric Mittman | 1845 views | 1 replies |
jball9299
Using WinServer2008 64 bit. MailEnable is handling emeil service for the domain. Created CDOSYS definition. Tries the domain.com, tried 127.0.0.1, tries the server name. No email from the ASP page. Contacted MailEnable to see what protocol I should use, they sent back the following.
They are asking you which component to use which will then connect to MailEnable, not the mail server type itself (since it would not matter as all SMTP servers should be able to accept the email). So it would depend on whether you have any of those components installed on the server. I would probably say it was CDOSYS, since that is Microsoft Windows component.
I am stuck. how do I install CDOSYS, ot some other compatible method? Am willing to hire the tech support if needed.
THANKS!
Jackson Ball
678-234-2821
jackson@artistesduglobe.com
CDOSYS is a object that should already be installed into your system, if it is not you might need to review some MS documentation for your OS on how to get it setup.
If you have CDOSYS installed then in DW when you apply Universal Email you should choose the CDOSYS mail object. When you finish crafting the Universal Email server behavior it will generate the code for the mail to be sent. You should test it out, if you do not have CDOSYS installed or enabled it should give you an error and point to the line of code that is trying to create the CDOSYS object.
Please post back if you have any further questions on this or experience any problems with Universal Email.
