centred slideshow ?
Thread begun 3/16/2010 12:41 pm by CraigR | Last modified 3/19/2010 2:52 am by CraigR | 8014 views | 24 replies |
CraigRBeta Tester
centred slideshow ?
i have created a css template page and am going through all of the gallery options, embedding the slideshow in the content div each time, which is centred and has a width of 920px
everything appears ok until i try to embed the slideshow galleries, which appear on the left rather than the centre of the page
css attached
neilo
Hi Craig,
Do you have an example of this online that you could link to?
What happens if you add text-align:center to your content div?
#outerWrapper #contentWrapper #content {
margin: 0 0 0 0px; /* Sets the margin properties for an element using shorthand notation (top, right, bottom, left) */
padding: 13px 13px 13px 13px; /* Sets the padding properties for an element using shorthand notation (top, right, bottom, left) */
text-align:center;
CraigRBeta Tester
thanks for swift reply Neilo
i tried the text-align: center but to no avail.
site not uploaded to server yet, but i will hopefully get it on line tomorrow.
cheers
you could also try setting the left and right margins in the content div to auto:
margin: 0 auto 0 auto; /* Sets the margin properties for an element using shorthand notation (top, right, bottom, left) */
text-align:center;
CraigRBeta Tester
i went back to first principles, and created a simple 1 column fixed centred layout with the ability to view all gallery formats.
as you can see, depending on the gallery chosen, the gallery shifts within the content div from centre to left
what i would like to do is have all of the galleries centred within my content div.
newphotolayout.php
neilo
Try changing the instances of .pg-rf in each of the gallery dark/light css files to:
.pg-rf {
margin: auto;
CraigRBeta Tester
cheers neilo, that seems to do it.
i just need to sort out the div height for the ribbon_fullsize and i'm done.
thanks a lot.
CraigRBeta Tester
whoops
just uploaded my entire gallery folder to my server to update the css and in my excitement have overwritten globals.php.
the php file looks simple enough and have changed the database name accordingly, but still getting error on page,(listed above).
regards
CraigRBeta Tester
here is the file...
thanks
neilo
Hi Craig,
Just something to try: change the variable '$database_stonepits1' back to '$database_powergallery', i.e:
require_once(realpath($abs_prefix . '../') . '/Connections/powergallery.php');
mysql_select_db($database_stonepits1);
To:
mysql_select_db($database_powergallery);
