Some fields will not insert??
Thread begun 3/20/2010 8:01 pm by mattoconnell298972 | Last modified 3/21/2010 7:55 am by mattoconnell298972 | 3686 views | 4 replies |
mattoconnell298972
Hi guys, this one has me stumped. I have used Data Assist to insert and update records many times - however I have a perculiar problem right now.
When I have an insert record instance, just from text fields at this stage, two of my fields will not insert.
All the others do fine. The two that won't insert are no different from the others (that I can see)
What could I possibly have wrong?
I will post the code page - but could the problem be in my database setup?? It appears to be ok??
Thanks!!
<?php require_once("../../WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
require_once( "../WA_SecurityAssist/Helper_PHP.php" ); ?>
<?php require_once('../../Connections/connTest.php'); ?>
<?php require_once( "../WA_Globals/WA_Globals.php" ); ?>
<?php require_once( "../WA_CMS/WA_CMS.php" ); ?>
<?php require_once('../Connections/localhost.php'); ?>
// WA Application Builder Insert
if ($_SERVER["REQUEST_METHOD"] == "POST") // Trigger
$WA_connection = $connTest;
$WA_table = "content";
$WA_sessionName = "contentID";
$WA_redirectURL = "newsDetail.php";
$WA_keepQueryString = true;
$WA_indexField = "contentID";
$WA_fieldNamesStr = "contentTitle|thumbImg|contentHome|contentLong|contentShort|date";
$WA_fieldValuesStr = "".((isset($_POST["contentTitle"]))?$_POST["contentTitle"]:"") ."" . "|" . "".((isset($_POST["thumbImg"]))?$_POST["thumbImg"]:"") ."" . "|" . "".((isset($_POST["contentHome"]))?$_POST["contentHome"]:"") ."" . "|" . "".((isset($_POST["contentLong"]))?$_POST["contentLong"]:"") ."" . "|" . "".((isset($_POST["contentShort"]))?$_POST["contentShort"]:"") ."" . "|" . "".((isset($_POST["contentDate"]))?$_POST["contentDate"]:"") ."";
$WA_columnTypesStr = "',none,''|',none,''|',none,''|',none,''|',none,''|',none,''";
$WA_connectionDB = $database_connPriefert;
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
<?php require_once("../../HTMLEditor/WARichEditorPHP.php"); ?>
<head>
<title>Priefert Australia - News Insert</title>
<script type="text/javascript" src="../css/mootools.js"></script>
<style type="text/css" media="all">
@import url('css/admin.css');
</style>
<!--[if IE 5]>
<style type="text/css">
/* IE 5 does not use the standard box model, so the column widths are overidden to render the page correctly. */
#outerWrapper #contentWrapper #leftColumn1 {
width: 170px;
#outerWrapper #contentWrapper #rightColumn1 {
width: 170px;
</style>
<![endif]-->
<!--[if IE]>
/* The proprietary zoom property gives IE the hasLayout property which addresses several bugs. */
#outerWrapper #contentWrapper #content {
zoom: 1;
</style>
<![endif]-->
<script type="text/javascript" src="../CSSMenuWriter/cssmw/menu.js"></script>
@import url("../CSSMenuWriter/cssmw/menu.css");
</style>
<!--[if lte IE 6]>
@import url("../CSSMenuWriter/cssmw/menu_ie.css");
@import url("../css/admin_ie6.css");
</style>
<![endif]-->
<link rel="stylesheet" type="text/css" href="../css/style.css" />
<link rel="stylesheet" type="text/css" href="../css/color.css" />
<link rel="stylesheet" type="text/css" href="../css/template.css" />
<link rel="stylesheet" type="text/css" href="../css/navigation.css" />
<link rel="stylesheet" type="text/css" href="../css/navigation_color.css" />
<link rel="stylesheet" type="text/css" href="../css/my_styles.css" />
<link href="../../WA_DataAssist/styles/Refined_Pacifica.css" rel="stylesheet" type="text/css" />
<link href="../../WA_DataAssist/styles/Arial.css" rel="stylesheet" type="text/css" />
</head>
<body id="subPage" onload="">
<div id="outerWrapper">
<div id="header">
<div class="left">
<a href="#"><img src="../../images/logoMain.png" alt="Power CMS" width="267" height="80" border="0" /></a>
</div>
<div class="right">
</div>
</div>
<div id="topNavigation">
<?php require_once("../CSSMenuWriter/cssmw/menu.php"); ?>
</div>
<div id="innerContainer">
<div id="innerRightContacts">
<div class="WADAInsertContainer">
<form action="newsInsert.php" method="post" enctype="multipart/form-data" name="WADAInsertForm" id="WADAInsertForm">
<div class="WADAHeader">
<p>&nbsp;</p>
<p>Create News Item
</p>
</div>
<p>Remember to select your thumbnail image to use before you press submit at the bottom.<br />
This image will also be used on the News Directory page.
</p>
<div class="WADAHorizLine"><img src="../WA_DataAssist/images/Pacifica/Refined_tx.gif" alt="" height="1" width="1" border="0" /></div>
<table class="WADADataTable" cellpadding="0" cellspacing="0" border="0">
<tr>
<th width="101" class="WADADataTableHeader"></th>
<td width="504" class="WADADataTableCell"><input type="hidden" name="contentID" id="contentID" value="" /></td>
</tr>
<tr>
<th class="WADADataTableHeader"><div align="left">Date:</div></th>
<td class="WADADataTableCell"><input type="text" name="contentDate" id="contentDate" value="<?php
print date('D, d M Y');
?> " size="20" /></td>
</tr>
<tr>
<th class="WADADataTableHeader"><div align="left">Title:</div></th>
<td class="WADADataTableCell"><input type="text" name="contentTitle" id="contentTitle" value="" size="60" /></td>
</tr>
<tr>
<th class="WADADataTableHeader"><div align="left">Thumbnail <br />
Image:</div></th>
<td class="WADADataTableCell"><input type="text" name="thumbImg" id="thumbImg" value="" size="60" /></td>
</tr>
<tr>
<th colspan="2" class="WADADataTableHeader"><div align="left">
<p>This content will appear on the home page when it is the most recent item.<br />
<br />
<textarea id="contentHome" name="contentHome" rows="3" cols="60" style=""></textarea>
</p>
<p>&nbsp;</p>
<p>This content will appear on the 'News and Events' page - maybe 4 to 6 lines of text and small image.<br /><br />
There will be an image from the thumbnail you just uploaded.</p>
</div></th>
</tr>
<tr>
<p>
<textarea id="contentShort" name="contentShort" rows="6" cols="60" style=""></textarea>
<br />
</p>
<p>&nbsp;</p>
<hr />
<p>&nbsp;</p>
<p>This is the detailed content which will appear on the News Detail page.<br />
Add all content you would like to be visible.</p>
</div></th>
</tr>
<tr>
<th class="WADADataTableHeader"><div align="left">Detailed Content:</div></th>
<td class="WADADataTableCell"><input type="text" name="contentLong" id="contentLong" value="" size="60" /></td>
</tr>
</table>
<div class="WADAButtonRow">
<table class="WADADataNavButtons" border="0" cellpadding="0" cellspacing="0">
<tr>
<td class="WADADataNavButtonCell" nowrap="nowrap"><input type="image" hspace="0" vspace="0" border="0" name="Insert" id="Insert" value="Insert" alt="Insert" src="../WA_DataAssist/images/Pacifica/Refined_insert.gif" /></td>
<td class="WADADataNavButtonCell" nowrap="nowrap"><a href="newsResults.php"><img border="0" name="Cancel" id="Cancel" alt="Cancel" src="../WA_DataAssist/images/Pacifica/Refined_cancel.gif" /></a></td>
</tr>
</table>
<input name="WADAInsertRecordID" type="hidden" id="WADAInsertRecordID" value="" />
</div>
</form>
</div>
</div></div>
<div style="clear: both"></div>
</div>
<div id="footer"></div>
</body>
</html>
CraigRBeta Tester
On quick inspection, the field names seem to match ok.
which fields aren't updating ?
as some of the fields are updating, i don't think its your database setup, for the fields not updating are you trying to insert text into a numerical field ?
is the date field one of the problems ?, if the format you are trying to input into the db isnt in mySQL format, then it will not work.
if this is the case, then you could process the input string before database input, or if the date is always the current date, you could leave it out altogether and have the database insertthe timestamp automatically.
mattoconnell298972
The date is ok....
Funny enough the date is fine....
It is the thumbImg and contentLong.
Neither seem to insert into the Db, and all have the same setup as other fields that are workng.
Bizarre?!
CraigRBeta Tester
not sure about this, but as the WADA server behavior does the redirect for you, should the form action be doing it too?
try setting the form action to "".
mattoconnell298972
Crisis Over
Thanks guys for the help, pointed me in the right direction...had an incorrect redirect!!!
