checkout problem
Thread begun 4/10/2010 9:28 am by jacob5136402106 | Last modified 4/16/2010 12:19 pm by Eric Mittman | 4067 views | 7 replies |
jacob5136402106
checkout problem
Problem:
when a single item is selected and the customer is directed to the checkout page automatically and the customer selects the 'PayPal Express checkout" button it directs the customer to Paypal, then after the customer comits to make the purchase and paypal sends the customer back to my store the confirm page stats: "Your shopping cart is empty", and no purchase has been made.But..
If the customer clicks on the "Veiw Cart" button first, then selects the Pay Pal checkout button, everything works as it is suppose to and the purchase is processed.
What I have done:
My site would only work using the sandbox feature so I modified the file as suggested by Tom M:
OK, there is a problem in the ECart PayPal Express Checkout Code.
Specifically, the file PP_ECO_PHP.php
Here are lines 309-315:
function WA_PP_ECO_CallSOAP($sXML, $useSB) {
$soapObj = new WAPPECOSOAPObject;
$soapObj->soapURL = "https://api-3t.paypal.com/2.0/";
if ($useSB) {
$soapObj->soapURL = "https://api-3t.sandbox.paypal.com/2.0/";
I changed them to this (I commented out the PayPal sandbox URL, and the URL is now universally set to the PayPal non-sandbox URL):
if ($useSB) {
// $soapObj->soapURL = "https://api-3t.sandbox.paypal.com/2.0/";
Guess what. PayPal Express Checkout now works as expected. Of course, use of the Dev Sandbox is now disabled.
After doing the above I was then able to make purchases thru Paypal but with the above problem of having to click on the "Veiw Cart" button first.
I set a product in my site for testing.
My site is:
www.jacobsfishinghole.com
The test product is under the catagory of "tools" and is called "Test-not real product". It is set at a price of $0.01. So if you would like to go to my site and try it you may.
Any help will be greatly appreciated.
Jacob
When I test this out with the URL you provided I can see the issue. I add the item to the cart, then choose to checkout with PayPal. When I'm returned to the site I get the your cart is empty message.
When I look up at the URL I can see why, you are being redirected back to jacobsfishinghole.com/ instead of www.jacobsfishinghole.com/. This value is based on the settings that are in your wa_settings table.
It should include any www or any other preset that you have for your site, when you installed did you install with a URL of jacobsfishinghole.com? If so this is probably the reason you are getting this error. You should be able to check and update this value by going into your db and looking in the wa_settings table. In here for the root URL you should add in the www part and save your update.
Please post back and let us know about this and also include some additional details about the sandbox issues you are having if they still persist.
jacob5136402106
Eric,
I opened my database and edited the wa_settings table to include the "www". Then I had my friend try it by selecting the product and clicking on the "PayPal" button which sent him to paypal. and when he was done there and was sent back to my site he had the same result of "cart is empty" message. I then opened the site in DW and edited the site (site management) so the url also included the "www".
Same result.
as previuosly stated I have a test product under the catagory of tools for $0.01
my site is
Thanks for your help
Jacob
shoconnor256175
This sounds like an htaccess problem that I've had with a joomla site and virtuemart.
The whois says you're with 1&1 and I am unfamiliar with the way they handle redirects, but check to make sure that all requests with or without the www point to the www.yoursite.com address. That is, in the address bar, if someone types yoursite.com that it automatically points them to the full address of www.yoursite.com and not just yoursite.com
I host with godaddy and its under their site redirects. If you're using cpanel I'm not sure how to do it, but I'll bet someone on this board or at 1&1 can help.
Around line 124 on your checkout page you should see where the return URL is set:
$WA_PP_ECO_Set_params[0][$nextIndex] = "ReturnURL";
$WA_PP_ECO_Set_params[1][$nextIndex] = "".$WAGLOBAL_Root_URL  ."pp_confirm.php";
This uses the global root URL that comes from your db and adds the 'pp_confirm.php' to it. Updating the value for the root URL on the live server should make this code go to the URL that is listed.
You could code the URL in here directly to see if it makes it work, to do that you would make line 125 look like this:
$WA_PP_ECO_Set_params[1][$nextIndex] = "http://www.jacobsfishinghole.com/pp_confirm.php";
If you do not get the proper result with this update then there is probably a setting somewhere on your server that is causing this problem. Please give this a try and let us know the result.
jacob5136402106
Fixed
Eric,
I changed the file as suggested above and now the checkout process is now working correctly. I had previously changed both my site information in DW and the url in my database to include the "www" as suggested without correcting the problem. But forcing the url (line 125 checkout.php) as suggested above worked.
Thank You,
Jacob
I'm glad that worked out, this might be an issue with the way the server is setup like shoconnor256175 was talking about. It should use whatever values are specified.
