eCart 4.5 update
I noticed there is a new eCart 4.5 update. Is it okay to install it if I already have an eCart site (v4.16)? This is something I always worry about with the dot updates--is there any general rule on this?
The general rule is that it won't update anything until you tell it to. In this case the update is primarily bug fixes so you shouldn't have to worry about stepping on any functionality.
In more major releases like a full version release that may be more likely, but it is still something we would try to avoid and would warn you about.
