Multiple emails
Thread began 4/26/2010 11:27 am by asnw0764437428 | Last modified 4/26/2010 3:49 pm by Jimmy Wu | 862 views | 1 replies |
asnw0764437428
Multiple emails
I have a business directory set up and I want to be able to request a quote from each of the businesses listed after a search has been completed, by clicking say for example a multi quote button. I also want the email addresses hidden from each recipient, ie sent as BCC
Can this be done using UE and if so, how? or is there a tutorial on this sort of request.
Many thanks for anyones input on this.
Jimmy Wu
This can be done using Universal email. You would just fill in the information the way you want it sent in the Universal Email wizard. Then you would apply the behavior once for each email you want sent. For the code added for each of the server behaviors, you would want to check if that is part of the search results and then determine if you want that behavior to be executed or not.
