Left column forces content to drop in right column
Thread begun 4/27/2010 9:33 am by Brad Lawryk | Last modified 4/27/2010 2:27 pm by Jason Byrnes | 4299 views | 8 replies |
Brad Lawryk
I have an issue that happens all the time when I use a two column layout. The content in the main content column always gets forced down and starts where the left column ends.
Hard to explain, here is a link:
index.php
Any help would be appreciated. It happens 100% of the time.
Thans,
Brad
it looks like this is a projct 7 issue.
something in the tab panels magic code is forcing the tabs along the top to use all of the availabel height in the content div.
perhaps try editing the p7tp_10.css file.
change:
.p7TP_tabs div {
display: block;
float: left;
margin: 0 -1px 0 0;
.p7TP_tabs div {
display: block;
float: left;
margin: 0 -1px 0 0;
height: 26px;
I cant guarantee that will work though, the height may be dynamically set through the javascript.
I would contact Project 7 if this does not do the trick.
Brad Lawryk
Its not a P7 issue, it happens with your own Data Assist Forms as well.
I'll post a screen shot from at home tonight.
In the mean time I will give this a try.
Thanks,
Brad
Brad Lawryk
Nope, didn't help.
But its definately not a P7 issue. Here is a screenshot with the layout with sculptor and the content added with Data Assist. Happens everytime on every site.
Brad
perhaps try changing:
#outerWrapper #contentWrapper #content {
margin: 0 0 0 220px; /* Sets the margin properties for an element using shorthand notation (top, right, bottom, left) */
padding: 10px 10px 10px 10px; /* Sets the padding properties for an element using shorthand notation (top, right, bottom, left) */
overflow: hidden;
Brad Lawryk
Thanks Jason,
That did the trick. I will make note of this and fix up all my other sites.
Appreciated,
Brad
no worries.
Brad Lawryk
I wonder if that is something that is fixed in Sculptor 3?
Brad
it is not so much a scluptor issue, it will need to be addressed in DataAssist
