table styling inside editor
on other configurations of the FCK editor there are usually options to style tables such as cell background colors and table background colors.
how can I get this facility on the expensive , license restrictive CMS 2 ?
When you add the table to the content area you should have the full set of options available to you, here is a screen shot of what you should see.
You can also right click on the table to adjust these settings and some others. These are the only table editing options available.
in other FCK editors there are options to color the cell background, also the color of the table.
also when the table is inserted there is no way to edit the table and add more rows or columns ?
selecting the table and clicking on "edit/i
nsert table" simply inserts a new table
These are the only table editing options that are available. When the table is in the editor already you need to right click on it to get the editing options.
