re: site import plug in
Thread begun 5/25/2010 10:12 am by pklogan205063 | Last modified 5/25/2010 6:42 pm by Eric Mittman | 1742 views | 1 replies |
pklogan205063
I am using Dreamweaver CS4. I attempted to use my site import plug in and when I clicked on the arrow button to start the process it gave me the usual dialogue box to enter the site and place to download it. However, below those fields it has a broken icon and "Error </head>, and at the bottom above "Got questions..." are four more broken image icons.
An additional dialogue box appeared and says the following: "While executing onFocus in WA_ImportSite.htm, the following JavaScript error(s) occurred: In file "WA_ImportSite": document.headerSearch has no properties"
I have attached a pdf of the above information. How do I fix this problem?
Thank you,
Pam Logan
pklogan@usa.net
805-528-8949
I did not see the pdf attachment on your post. You may be experiencing an issue related to a bad cache file, here are the steps you can take for deleting this file:
If this does not resolve the issue there might be a corruption of your configuration somewhere. Here are the steps that you will need to take if deleting the cache file does not solve the problem for you:
showpost.php?p=12293&postcount=2
If you still have this problem after trying both of these we will need to look into the issue further. Please post back and let us know the result.
