transaction only successful with $1 not $1.00 (eway payment gateway)
Thread begun 5/28/2009 7:48 am by email377288 | Last modified 5/28/2009 3:37 pm by Ray Borduin | 5670 views | 7 replies |
email377288
this is very strange...i have been testing for hours and i can't get a successful transaction when my cart has a decimal place defined.
if i redefine the cart and uncheck the "force decimal checkbox" and insert "value 0" in its text field, i then get a successful transaction.
i have tried this in both live and test modes with the gateway, same result.
biggest problem is when i put through a live transaction with no decimal place defined e.g $1 i get $0.01 deposited in my account!
as i don't really want to be responsible for putting the client out of business! please help if you can...
I am not familiar with this problem, but it sounds like you could multiply the value by 100 and it would all work out.
Have you looked at the full request and full response to try to spot what might be wrong in the code?
email377288
i have had a look but as i have limited knowledge of php i'm not really sure whats going on, i assume the bug is in Adv_CO_Scripts\eWAY_XML_PHP.php
here is a snippet from that file...
$WA_eWAY_VersionNumber = "2.20";
function eWAY_XML_Post($reqArray,$itemArray,$optArray) {
global $WA_eWAY_VersionNumber;
$varvalueArray = array();
for ($x=0; $x<count($reqArray[0]); $x++) {
$varvalueArray[strtolower($reqArray[0][$x])] = $reqArray[1][$x];
for ($x=0; $x<count($optArray[0]); $x++) {
$varvalueArray[strtolower($optArray[0][$x])] = $optArray[1][$x];
for ($x=0; $x<2; $x++) {
$varvalueArray[strtolower($itemArray[0][$x])] = $itemArray[1][$x];
$usecvn = ((isset($varvalueArray["usecvn"]) && $varvalueArray["usecvn"] == "true") ? true : false);
$usetest = ((isset($varvalueArray["testingserver"]) && $varvalueArray["testingserver"] == "true") ? true : false);
$usest = ((isset($varvalueArray["storedtransaction"]) && $varvalueArray["storedtransaction"] == "true") ? true : false);
$postXML = "<ewaygateway>".
"<ewayCustomerID>" . $varvalueArray["ewaycustomerid"] . "</ewayCustomerID>".
"<ewayTotalAmount>" . $varvalueArray["ewaytotalamount"] . "</ewayTotalAmount>";
is it something to do with the statement ($x=0; $x<2; $x++) from line 14?
Try:
"<ewayTotalAmount>" . ($varvalueArray["ewaytotalamount"]*100) . "</ewayTotalAmount>";
Please post a support incident on this issue it appears it must be a bug.
email377288
thanks this has got it working correctly, will post a support incident on the issue.
not sure if its related but when i add an item to cart with a price of $0.10, the quantity field in the cart also shows 0.1 is this also a bug, i would have thought you cannot buy decimal places of an item? it allows me to do the whole checkout with the quantity set to 0.1
my setup is powerstore reading product information from the products table in the database
You can set up quantity to be a number or an integer in the eCart defintion. Some people sell product by the pound or ounce and quantity can have decimals.
The quantity update seems wrong. It should have a quantity of 1 regardless of the price.
email377288
my ecart definition shows quantity type = number (default from install)
also in the database ProductStock type = float (default from install)
is float the correct type in the database? i only require whole numbers for stock and no decimals
Change them both to integer and they will only accept whole numbers (note: you will have to reapply the add to cart server behavior after the change to take effect)
email377288
This post has been deleted.
