Using CSS Menu Writer With Site Sculptor
Thread begun 6/15/2010 11:56 am by larry268887 | Last modified 6/17/2010 1:48 pm by larry268887 | 3791 views | 5 replies |
larry268887
When you create a site sculptor site using one of the presets for site sculptor two menu.php files are created.
One menu.php file for the home page and one menu.php file for the content pages.
In both menu.php files $WA_localRoot = "" . $WAGLOBAL_pcms_remote_root . ""; and $WA_remoteRoot = "" . $WAGLOBAL_pcms_remote_root . "";.
This assigns both of the variables to pcms_remote_root which is found in the wa_settings table of your database. And as long you install CMS on the testing server and also install CMS on the remote server everything will work just fine.
Here is were the problem comes if you modify the menu using CSS menu writer. Menu writer will edit the two menu.php files and in both files
$WA_localRoot = "Parti Yorkies"; (as an example)
$WA_remoteRoot = "/"; (If the site definition is set up incorrectly)
Once this happens all your links will have an extra Parti Yorkies folder in the URL.
Until Webassist corrects the BUG a workaround would be to replace
in the two menu.php files with
With this fix your testing server menu and your remote site menu will work correctly.
Another workaround would be to replace
$WA_localRoot = "/";
If you go this route only the menu on the remote server will work properly.
The menu will not work properly on the testing server.
So I would recommend the first fix.
It been six days and webassist haven't even acknowledged that there is a problem so no telling how long it will take to correct the problem.
As you have noted the editing of a Site Sculptor site with CSS Menu Writer will cause the menu files to be overwritten. This is one reason we do not suggest using menu writer to update the menu on the completed site. Rather than update the existing menu you should be generating a new Site Design for Site Sculptor based on the menu you would like to include.
You can then quickly and easily create a new site based on the new design. What Site Sculptor generates should be a site with the pages, templates, and menus existing for you. You can then customize the site or update the contents via the content management.
larry268887
I understand but here is the problem. Lets say you have a dynamic site and many of the pages have a portion of the content is dynamic. I don't think many people would want this portion to be editable by a customer. Every time one needs to change the menu then that means that all the pages that contain content that is CMS and database driven would have to be manually edited. This could be very time consuming.
Am I correct in what I'm saying or is there something I'm not aware of?
To me it would be essential that CSS menu writer is compatible with Site Sculptor.
larry268887
When you look at your literature in the features section on Site sculptor it says "# Compatible with CSS Menu Writer
* Import a custom menu created with CSS Menu Writer
* Customize your menu further with CSS Menu Writer 2"
showthread.php?p=61819&posted=1#post61819
Originally Said By: Neil Beadle
  Sure can! There is a simple menu.php file that contains the unordered list that you can add any additional links to. For some more functionality when modifying the menu, you can use CSS Menu Writer.
menu Writer wasn't created to be aware of the Global Settings that are Created by site Sculptor if you select the option to use CMS, so yes it will overwrite the Local Root and Remote Root settings.
I will have this logged as a bug, it will need to be fixed in menu writer.
Really though, as long as the Site Settings for HTTP Address on the Local Info tab and URL Prefix on the testing server tab are configured properly, the change made by menu writer should not have any effect.
In your site definition, how have you set the HTTP Address on the Local Info tab?
What is the URL Prefix on the testing server tab?
In the database created by site sculptor, what is the value for the PCMS Remote Root record?
larry268887
The HTTP address is www.elvis-parti-yorkies.com/
The URL Prefix is Parti Yorkies/
PCMS remote Root = /
I agree with you that is why I think there is a bug in the way siteassiste css menu writer.
