localhost with Dreamweaver CS3
Thread begun 6/17/2010 1:08 pm by joe405450 | Last modified 6/30/2010 5:20 pm by Eric Mittman | 12143 views | 6 replies |
joe405450
I started using Dreamweaver CS3 in December 2009, and love it. I developed a website for my lodge over the last 6 months, much of it static. I am undertaking the addition of e-cart and dynamic pages with PHP using Webassist products. My issue is with localhost. Below are current set-ups:
operating sys: windows XP pro
software: dreamweaver CS3; Xammp
Local Root folder: C:\Documents and Settings\Admin\Desktop\new_Hills_25_site\
Http address: www.hillsborough25.org/
Remote host / directory: hillsborough25.startlogic.com/public_html/
Testing server folder: C:\Documents and Settings\Admin\Desktop\new_Hills_25_site\
URL prefix: webtest
I have verified that PHP is running on my computer, and have been able to build databases and tables. I cannot get dreamweaver to connect!!! I've spent 2 days trying to figure this out, and did not want to have to rebuild entire site.
I keep getting HTTP 404 errors from dreamweaver.
Please help me
What is the exact error you are getting when you try to connect? I have seen before where 404 errors occur for the _mmServerScripts directory. These files should hold information about your site and connection. If they are bad in any way you can have problems like this. I would suggest duplicating the DW site, then deleting the _mmServerScripts folder along with the connection folder and try creating a new connection.
joe405450
Ok..I tried removing the mmServerScripts folder, relocating the entire site to the directory where the localhost is located, and retried the connection with the following settings:
MySQL server: xampp/
User Name: root
Password: xxxxxxxxxx
Database: hills25_data
The error message I get is the same -
Http Error Code 404 File Not Found. Here are some possible reasons for the problem:
1) There is no testing server running on the server machine
2) The testing server specified for this site does not map to the MMHTTPDB.php URL. Verify that the URL Prefix maps to the root of the site.
As a point of information, below is the mapping for the site definition:
Local root folder: C:\xampp\htdocs\test_hills25\
Default images folder: C:\xampp\htdocs\test_hills25\images\
HTTP address: test_hills25/
Testing server folder: C:\xampp\htdocs\test_hills25\
URL Prefix: test_hills25/
I cannot believe that this operation can be this difficult. I purchase Security Assist, Data Assist, E-Cart, and Universal Email to help make programming much more efficient. So far, the only one that hasn't given me any trouble is Universal Email.
Please help with this, as I am running very close to deadline on my project.
Joseph
The error you are getting is not from any of our extensions, it is coming from Dreamweaver. It is telling you that there is a problem with the way that the testing server is setup. The message is saying that the script file cannot be found in the location it is looking for it. This is one of Dreamweavers internal resources that are used to manage your site. The file and location it is looking for is:
MMHTTPDB.php
Based on your site settings it looks like your testing server URL is wrong, if the web root for xamp is located in C:\xampp\htdocs\ then the URL for the testing server should be like this:
test_hills25/
The localhost will map to the root of the web server so you should not list the folders that come before this.
joe405450
THANK YOU SO MUCH!!! I was able to connect by changing the URL and removing the additional folders. You've been a great help; have a GREAT day!
Joseph
joe405450
security assist error
Eric,
I've managed to get all pages working on my localhost, created and connected to a database, worked through and installed Data Assist. I put Security Assist on as well for security of Admin, and all pages for Security Assist work fine, expect for a few pages using Data Assist (these were working before). Here is the errors I get when trying to search a database, or follow a link from the admin main menu:
Warning: require_once(../../WA_SecurityAssist/Helper_PHP.php) [function.require-once]: failed to open stream: No such file or directory in C:\xampp\htdocs\test_hills25\webassist\email\mail_php.php on line 1
Fatal error: require_once() [function.require]: Failed opening required '../../WA_SecurityAssist/Helper_PHP.php' (include_path='.;C:\xampp\php\PEAR') in C:\xampp\htdocs\test_hills25\webassist\email\mail_php.php on line 1
Any ideas on how to fix this?
Thanks,
Joseph
The error you are getting now is telling you that the include files cannot be found in the location specified in the link. Rite now it is looking for the files here:
Based on the location of the file that is giving you this error:
C:\xampp\htdocs\test_hills25\webassist\email\mail_ php.php
It would be looking for this file in
C:\xampp\htdocs\test_hills25\WA_SecurityAssist\Helper_PHP.php
Do you have these files in this location? If you find these files in your site and make sure they are in this location you should not get these errors.
