HTML Quotes added to record when pulled for update
Thread began 6/18/2010 11:22 am by scott351953 | Last modified 6/25/2010 10:11 am by Jason Byrnes | 2219 views | 7 replies |
scott351953
I am using the old version of irite and built a content manager to help my client update their pages. Everything was working great untill I ran the security assist wizard to lock down all the pages (not sure if this has anything to do with it). I went back to update one of the records, after I got to the update page... Non of the images showed up. I check the source, and this is how it was changed:
Before the update:
<img border="0" alt="" width="488" height="189" src="/userfiles/19x10.gif">
After the update:
<img border="&quot;0&quot;" width="&quot;488&quot;" height="&quot;189&quot;" src="&quot;/userfiles/19x10.gif&quot;">
Any one know what the deal is?
It looks like you may have some formatting being applied to the default value of the editor. What do you have the value in the editor set to? If you have any trouble finding this post back with a copy of the page that has the editor and update server behavior on it as well as the insert page.
scott351953
You are correct!
I double checked the value and there was a wacky little string in for the initial value. I just replaced it and everything works fine. I think it autopopulated when I ran the wizard. Thanks again, as always!
That was kind of what I was thinking. I'm glad that you sorted it out, let us know if you have any other questions.
designgraphic
Same Problem
I am having the same problem...
The code that was added when I placed the HTML editor in the text area is the following:
// WebAssist iRite: Rich Text Editor for Dreamweaver
$WARichTextEditor_2 = CreateRichTextEditor ("memNewDocEn", "../HTMLEditor/", "100%", "400px", "Default", "../custom/tblNews_Update_memNewDocEn1.js", "".(str_replace('"', '&quot;', $row_WADAtblNews['memNewDocEn'])) ."");
Although I am not very familiar with php, it seems that says to replace the " with &quot and this is what makes all the trouble in the images not showing correctly...
May you please advice on how to replace the code.
change:
"".($row_WADAtblNews['memNewDocEn']) .""
designgraphic
Great!!!
Thank you so much. It works great.
excellent, glad to hear it is working.
