DataAssist Results Issue (when live)
Thread begun 6/21/2010 11:23 am by braduhl | Last modified 7/12/2010 10:29 am by Jason Byrnes | 6202 views | 17 replies |
braduhl
DataAssist 2.0.7
Dreamweaver CS4
Windows 7
I'm hoping someone can help me with this issue:
I have a search form and results page that works perfectly when testing locally. The results page contains two recordsets, one for our glassware search, and one for our awards (we precision carve glassware & crystal products).
Once posted to the webserver, the Keyword/part number search does not work, but the price range does.
For the life of me, I do not understand why it works locally flawlessly, but does not work when posted live.
I have attached the search form page, the search results page, and the DataAssist HelperJS.asp file. Please let me know if there is anything else you may need.
Thanks in advance for your help.
Brad Uhl
Crystal Carvers Inc.
1-800-365-9782
CraigRBeta Tester
when you say it does not work, do you get any error messages, or does it just not return the results you expect ?
do you have a link to the live page ?
braduhl
It just does not return results when it should. As mentioned, locally it works perfectly when tested.
The site is live at www.crystalcarversinc.com. Click on the Search button and type in a keyword (like mug, or wine). It is if it is not passing any information to filter the recordset.
If you put in a price range, it works just as it should.
Please let me know if you have any other questions...
Thanks for your help!!!
Brad
1-800-365-9782
CraigRBeta Tester
I can confirm that I get the same problem from your link.
The search parameter is being passed into the query, but there appears to be no matching data.
(if the parameter wasn't being passed, the query would return all rows)
One thing that springs to mind.
If you are running on a linux host, ensure that the 'case' of the field doing the filtering is correct.
I know that windows is not case sensitive, but linux is, (which may be one reason why it works on your local machine).
if this doesn't help, you could try echoing the sql statement to the page so you can see it, which may help identify the problem
(sorry, just realised you are using asp not php, you would use Response.Write to display the sql rather than echo).
braduhl
Hi Craig,
Just wanted to let you know that when trying out a different webhost, the search worked just fine. Unfortunately, the webhost I have decided to go with, we're back to the same problem.
Even though I am currently in school to continue my web design education, I am still learning. How should I be using Response.Write to display the SQL information to the screen? Where is the best place for the code?
Thanks again for your help...
Brad
CraigRBeta Tester
Hi Brad.
It is strange that the same site works fine with a different hosting provider, suggesting that there is nothing wrong with the code - per se.
I am a bit rusty with asp, but essentially, the response.write instruction was posted so you could view the sql on the page after it was created.
(i can't test for this, so i hope its ok), below line 82, try, for example... response.Write(rsCatSearchGW_cmd.CommandText)
on your page, any time after DataAssist has created the sql the code, you can write the code to the page using this method
as a debugging method, i occasionally do this, then take the sql statement and pass it into my database manually to check for any errors.
Perhaps someone from Webassist can help a bit more ?
Hope you don't mind me suggesting, on another subject, i notice your site is frame based.
I would urge you to move away from this if you want the site to be found by search engines
braduhl
Hi Craig,
Thanks for the information, I wil give that a try and let you know the outcome.
As far as my Frame-based site, I completely agree. I am currently in the process of learning CSS and will be doing some re-design as soon as possible. I at least wanted to get what I had worked on (for about two years) out there to our customers in the meantime.
I appreciate your recommendation and agree that I need to get rid of the old way of doing things :-).
Brad
braduhl
Hi Craig,
I placed "response.Write(rsCatSearchGW_cmd.CommandText)" after Line 82, which caused the infamous Red Exclamation Point beside any dynamic text referrencing the recordset, but still displayed the information that we were after on the results page.
SELECT * FROM qry_Products WHERE ProductTypeName = 'Glassware' AND ProductDisc = 0 ORDER BY ProductID
I'm still trying to figure out how the information from the search page (keyword, part no., etc.) becomes part of the SQL Statement for filtering on the results page? It's a little confusing to me.
I'm used to passing a variable from the previous page to the recordset for the filtering criteria, but there are no variables defined in the recordset to 'grab'. Can someone explain this to me?
Thanks once again.
Brad
the way data assist search works is to dynamicly create the where cluase to filter the recordset, and append it to the recordset select statement before it is executed.
One strange anomaly I see in the code, is that the price form elements are being referanced using the generic Request collection, but the keyword element is being referanced using the Request.Form collection. For example, line 16 - 18:
WADbSearch1.keywordComparison(KeyArr0,"" + String(Request.Form("tfKeyword")) + "","AND","Includes",",%20","%20","%22","%22",0);
WADbSearch1.addComparison("ProductRetPrice","" + String(WADS_stripCurrency(Request("tfMinPrice"))) + "","AND",">=",1);
WADbSearch1.addComparison("ProductRetPrice","" + String(WADS_stripCurrency(Request("tfMaxPrice"))) + "","AND","<=",1);
try changing line 16 to:
WADbSearch1.keywordComparison(KeyArr0,"" + String(Request("tfKeyword")) + "","AND","Includes",",%20","%20","%22","%22",0);
if that does the trick, you'll also want to change line 52:
WADbSearch1.keywordComparison(KeyArr0,"" + String(Request.Form("tfKeyword")) + "","","Includes",",%20","%20","%22","%22",0);
WADbSearch1.keywordComparison(KeyArr0,"" + String(Request("tfKeyword")) + "","","Includes",",%20","%20","%22","%22",0);
braduhl
Hi Jason,
Hope all is well & thanks for your assistance - it's been a while :-).
I made the revisions per your post, still to no avail.
The search feature still works perfectly when tested locally, just not when live. It acts as if there is nothing that matches the criteria.
Any other thoughts?
Thanks!
Brad
