last item in cart
Thread begun 6/01/2009 6:55 am by CraigR | Last modified 6/01/2009 8:06 am by CraigR | 1560 views | 1 replies |
CraigRBeta Tester
last item in cart
I am looking for a way to retrieve the itemid (and from this its category and categoryid) from the last item added to the cart.
I tried creating an array on the cart page, to populate as the basket looper code is run, but this doesn't give me the desired result if i add 2 of the same item non-consecutively.
CraigRBeta Tester
solution ?
i managed to do this by creating a session variable and setting it to the same value as $ATC_itemID within my cart function
i then retrieved the value on my cart page.
