Files uploading, but where?
Thread begun 6/29/2010 1:10 pm by Blikbrein | Last modified 6/29/2010 3:07 pm by Jason Byrnes | 1079 views | 1 replies |
Blikbrein
I've created a form - baicform.php
2 fields require images to be uploaded
These images should be uploaded to the applicants folder and the whole form posts to the thankyouapplication.php page.
This page is set up to mail(before page load)the form content + attach the 2 uploaded files to selected email.
Only the form field detail is mailed. Files are not uploaded to the selected folder nore attached to the email.
There are so many places I could have gone wrong. What must I change?
Wanted to upload files, but manage attachment button does not open anything when clicked...
you have the action of the form set to post to the thankyouapplication.php page, this is by passing the image upload function.
set the form to post to itself instead.
you will also need to apply the universal email behavior to the baicform.php page instead of the thankyouapplication.php. you can set the universal email to redirect to the thankyouapplication.php page after the email is sent.
to attach the uploaded files to the email, on the attachments tab, select entered Value.
Click the lightning bolt next to value and Expand the Uploaded Files (Files field Name) Binding group. Select the Server Directory binding.
this will add code similar to:
<?php echo $WA_DFP_UploadStatus["WA_UploadResult1"]["serverDirectory"]; ?>
copy that code and then click the lightning bolt again, select the server File Name Binding. This will add code similar to:
<?php echo $WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"]; ?>
you will need to past the previous code in front so it looks like:
<?php echo $WA_DFP_UploadStatus["WA_UploadResult1"]["serverDirectory"]; ?><?php echo $WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"]; ?>
