Download trying to download itself
Thread begun 7/22/2010 10:13 am by sandy259886 | Last modified 7/23/2010 6:53 am by Jason Byrnes | 3217 views | 5 replies |
sandy259886
Universal Email download form action has to be set for the form button to make the file download. I set the action to the same page (pagename) and when I click the download button, the current page downloads ... not the download file specified in the download server behavior.
How do I set the form action so that it will work and not try to download itself?
please send a copy of the page so I can examine the code.
sandy259886
copy of page
error_reporting(E_ALL);
?><?php require_once('../../Connections/xxx.php'); ?>
<?php require_once("../../webassist/file_manipulation/helperphp.php"); ?>
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$colname_rsebook = "-1";
if (isset($_GET['ebook'])) {
$colname_rsebook = (get_magic_quotes_gpc()) ? $_GET['ebook'] : addslashes($_GET['ebook']);
mysql_select_db($database_traders, $traders);
$query_rsebook = sprintf("SELECT * FROM prod WHERE EbookLink = %s ", GetSQLValueString($colname_rsebook, "text"));
$rsebook = mysql_query($query_rsebook, $traders) or die(mysql_error());
$row_rsebook = mysql_fetch_assoc($rsebook);
$totalRows_rsebook = mysql_num_rows($rsebook);
$paramItemNo_rsDesc = "-1";
if (isset($row_rsebook['itemNumber'])) {
$paramItemNo_rsDesc = (get_magic_quotes_gpc()) ? $row_rsebook['itemNumber'] : addslashes($row_rsebook['itemNumber']);
$query_rsDesc = sprintf("SELECT * FROM proddesc WHERE itemNum = %s", GetSQLValueString($paramItemNo_rsDesc, "text"));
$rsDesc = mysql_query($query_rsDesc, $traders) or die(mysql_error());
$row_rsDesc = mysql_fetch_assoc($rsDesc);
$totalRows_rsDesc = mysql_num_rows($rsDesc);
$paramItemNum_rsAuthor = "-1";
$paramItemNum_rsAuthor = (get_magic_quotes_gpc()) ? $row_rsebook['itemNumber'] : addslashes($row_rsebook['itemNumber']);
$query_rsAuthor = sprintf("SELECT * FROM assignauth, authors WHERE prodID = %s AND assignauth.authorID = authors.AuthID", GetSQLValueString($paramItemNum_rsAuthor, "text"));
$rsAuthor = mysql_query($query_rsAuthor, $traders) or die(mysql_error());
$row_rsAuthor = mysql_fetch_assoc($rsAuthor);
$totalRows_rsAuthor = mysql_num_rows($rsAuthor);?>
WA_DFP_SetupDownloadStatusStruct("WA_DownloadResult1");
if(isset($_POST["download"])){
WA_DFP_DownloadFile("WA_DownloadResult1", "../../../_downloadFiles", "".$row_rsebook['EbookLink'] ."", "".$row_rsebook['EbookLink'] ."", false, false, false, "", "", "", "");
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
<link href="../../siteassist_css/style.css" rel="stylesheet" type="text/css" />
</head>
<body>
<p>&nbsp;</p>
<table width="750" align="center" cellpadding="5">
<tr>
<td colspan="3">
<p>Item Number: <?php echo $row_rsebook['itemNumber']; ?></p>
<h3><?php echo $row_rsebook['Title']; ?><?php echo $row_rsebook['subTitle']; ?></h3>
</td>
</tr>
<tr>
<td width="150" align="center" valign="top">
<p><img src="../../bookimages/<?php echo $row_rsebook['SmallImage']; ?>" alt="<?php echo $row_rsebook['Title']; ?>" /></p>
<p>Author(s):<br />
<?php do { ?>
<?php echo $row_rsAuthor['AuthFName']; ?>&nbsp;<?php echo $row_rsAuthor['AuthLName']; ?><br />
<?php } while ($row_rsAuthor = mysql_fetch_assoc($rsAuthor)); ?></p>
</td>
<td colspan="2" valign="top">
<p><?php echo $row_rsDesc['shortDesc']; ?></p>
<div style="margin:25px">
<form id="downloadForm" name="downloadForm" method="post" action="download.php">
<input type="submit" name="download" id="download" value="Download eBook" />
</form></div>
<p>&nbsp;</p>
</td>
</tr>
</table>
<p>&nbsp;</p>
<p>&nbsp;</p>
</body>
</html>
mysql_free_result($rsebook);
mysql_free_result($rsDesc);
mysql_free_result($rsAuthor);
change the forms action to:
<form id="downloadForm" name="downloadForm" method="post" action="download.php?ebook=<?php echo(isset($_GET['ebook']):$_GET['ebook']:""); ?>">
so that the ebook querystring variable being used by the rsebook recordset has a value when the form submits.
sandy259886
working now using session variable
Well ... your solution didn't work, but it let me know that if I could get that variable set correctly, it might solve the problem. On pageload, I set a session variable for the record number. I used that session variable in the form action to set the page correctly. The download is working now. Thanks so much. Sometimes it takes 2 minds to figure it out.
OK, glad to hear it is working now.
