eCart recordsets
Thread begun 7/25/2010 11:02 pm by david331670 | Last modified 7/26/2010 4:40 pm by Eric Mittman | 1868 views | 3 replies |
david331670
eCart recordsets
Hi
I would like to have a link to a page with a repeating region that will display a "Subgroup" number in the repeating region. The "Subgroup" number will be passed on from the originating page. I have tried the page link" AccessoriesList.php?Subgroup=146" as well as AccessoriesList.php<?php echo $row_rsAccessories146['ItemID']; ?>
Both work. I have dynamic links from the recordset on the list page to display the name, desc, price etc. I have a large number of groups and I would like to set up only 1 Accessory page and have the page populated by the detail from the link. I'm have trouble with the binding.
Do I need to set up a session variable or something like that and how do I set up the binding on the repeat table on the accessory page to display only the subgroup number??
Am I trying to be to clever?
Thanks as always for your help
David
You are on the rite track here. The idea is that you need to link to this same page for all of the groups and just pass in the appropriate id. On this page with the recordset you will need to filter the recordset with this new URL parameter. In your recordset interface at the bottom you should have the option of filtering, choose the id column that your value will match with then specify to filter this column on a URL parameter and enter the name of your parameter, Subgroup.
Then whenever you link to this page with the Subgroup parameter set to a valid id it should filter the recordset and give you only the records from this Subgroup. The link will need to look like your example:
david331670
Recordset
So Close yet so far.
Thank you I got it and it works
David
That is good to hear, let us know if you have any other questions.
