confirm.php white space
Thread begun 8/02/2010 11:03 am by watercolor346374 | Last modified 8/05/2010 10:45 am by Jason Byrnes | 2268 views | 3 replies |
watercolor346374
Everything was working well until I added to the ecart database on the orders table...did exact same thing on order_items and had no problem. Now I get this message after clicking on checkout to go to confirm order...
Parse error: syntax error, unexpected T_ENCAPSED_AND_WHITESPACE, expecting T_STRING or T_VARIABLE or T_NUM_STRING in /Applications/MAMP/htdocs/winkee/confirm.php on line 136
Well that is where my insert to orders statement is. and it worked until I did this........
Just added to the orders datatbase: $winkee->DisplayInfo("onbackorder")
I have included my confirm.php script...also when I go into ecart database summary for orders I get this message before it loads up: it appears that one of your server side values is improperly coded. Please check this interface for inconsistencies.
Thank you,
K
I see a lot of codeing problems in the store order summary behavior.
you will need to rebind each of the columns to correct these problems.
In the store order summary behavior, select each column, click the lightning bolt next to value and reselect the corresponding variable.
watercolor346374
confirm.php
Hi Jason,
I went through all of the bindings. I can add the backorderstatus to the order_items table and it all runs right and I get the posting to the db table order_items that I want. When ever I do the same thing to the orders table, it does not work and that is when I get the white space message. I know that when I go into the ecart store sum for the orders table I get a message about server side coding areas and when I rebind them, the script does not work. I am not sure what is not correct. Here is the script without the backorderstatus added to the orders table. I included the detail page since that has all of the ATC items. As I look a what I want to do in the orders table may be impossible, since the backorderstatus is for each item and comes from the inventory table, so it will post for each item ordered. I still need to know what is wrong with my bindings, is that why I get the message that I have errors in my orders table?
Thank you,
K
I do not see an issue with the bindings fore the store order summary, they all look correct to me.
what you say is correct, the backorder message is unique to the item, so should not be stored in the orders table, it should be stored in the order details table.
if the backorder message is storing correctly in the details table, i would leave it as is.
