Filter results by dynamic drop down
Thread begun 8/28/2010 3:37 pm by mckenzie135328 | Last modified 8/31/2010 8:43 am by Jason Byrnes | 4689 views | 9 replies |
mckenzie135328
How do I filter the results of a DataAssist results page via a drop down that is triggered after making a selection instead of the DataAssist Search form that you can lump at the top of the results page?
I haven't done this stuff for about 6 years when I built a custom CMS using interAKT's tools. I remember back then it was easy to populate the drop down with a related tables field/values that could be used to filter your current results page.
In this case the results page will only have 3 fields: img url, name and type.
I need to be able to filter the results by type via a dynamic drop down menu.
The type field is a related field to another table.
Thanks in advance!
CraigRBeta Tester
Have you seen the dynamic dropdowns extension ?
it allows you to create cascading parent and child dropdowns from your recordsets.
mckenzie135328
Drop Downs
Do I have to combine that with DA Search in order to filter the results?
Sorry for any dumb questions, I only got the extensions yesterday.
CraigRBeta Tester
no you don't need DA at all to use this extension, it is separate
mckenzie135328
Drop down
I know that, but can it be used in conjunction with DA to filter a DA results page?
Yes it can.
You can use the dynamic dropdowns just like any other form element to filter the results page.
mckenzie135328
drop downs
is there a guide anywhere on how to do this?
dynamic dropdowns are just like any other form element.
when creating the recordset, in the filtering section, select the column that should be filtered. set the type to Form and then enter the name of the dropdown.
mckenzie135328
Drop Downs
Thats what I thought and vaguely remembered although without a default value the results will be blank.
My sql is:
SELECT id_prd, name_prd, type_prd, tnailurl_prd
FROM products_prd
WHERE type_prd = colname
Colname =
Numeric
Default -1
$_POST['type_dropdown']
The Default value returns no records. How do I get the default to return all records?
you cant do this using a regular recordset, you would need to use DataAssist Search
set the criteria to use the select list and the type_prd column
