Accordian Misspelling in code
Thread begun 9/15/2010 5:31 pm by carlene | Last modified 9/16/2010 10:57 am by Jason Byrnes | 2918 views | 5 replies |
carleneBeta Tester
Hi there -
I got a syntax error on this piece of code:
echo($Accordian[1]);
</script>
Note the spelling of Accordion. I'm guessing that's the culprit? The original piece of code is in the Main.dwt.php template.
Cheers!
Carlene
there should be this code on the page as well that initializes the Accordian array:
$Accordian = getCatAccordian();
echo($Accordian[0]);
what exactly is the syntax error?
Where can I see it?
Can you send a page that shows the code causing it?
carleneBeta Tester
Jason -- "Accordian" is being spelled incorrectly there. The proper spelling is Accordion. I'm guessing that is what the syntax error is pointing to.
irregardless of the proper spelling, it is being misspelled in both places.
misspelling will not cause a syntax error, unless the misspelling is inconsistent.
The php processor has no notion of proper or improper spelling of words.
the misspelling of accordion is not the cause of the syntax error
Where can I see it?
carleneBeta Tester
Jason,
So I fixed the spelling error and there was a blank line between the
?> and the
and that's what it was pointing to. I removed the blank line and the syntax error went away. (Dreamweaver was telling me there was an error with error reporting on.)
the spelling error will not cause a syntax error.
