Memory size error?
Thread begun 10/01/2010 3:16 pm by Steve | Last modified 11/11/2010 5:16 pm by Dani Chankhour | 11478 views | 26 replies |
Steve
Memory size error?
I'm trying to give the Framework Extension another try... Using the latest released Framework Ext
Created a nice new DW Template. Added a couple pages as static plugins for nav etc
Then created a new theme based on this template.
Create a new page from the Theme
Now I get this really nice error:
Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 40961 bytes) in E:\Websites\....
What the?
Steve
More details
I guess I might as well give the various page contents to help solve this problem.
Theme Template:
<head>
<!-- TemplateBeginEditable name="doctitle" --><!-- TemplateEndEditable -->
<!-- TemplateBeginEditable name="head" --><!-- TemplateEndEditable -->
</head>
<body>
<!-- TemplateBeginEditable name="contentRegion" --><!-- TemplateEndEditable -->
</body>
</html>
New page created with Theme:
require_once( "webassist/framework/library.php" );
require_once( "webassist/framework/framework.php" );
if("" == ""){
$WA_Roster_1285970700029_Content_Empty = "";
$WA_Roster_1285970700029_Content = new WA_Include(__FILE__);
$WA_Roster_1285970700029_Template = new WA_Include("Templates{$WA_Roster_1285970700029_Content_Empty}/Roster.php");
require($WA_Roster_1285970700029_Template->BaseName);
$WA_Roster_1285970700029_Template->Initialize(true);
<html xmlns="http://www.w3.org/1999/xhtml"><!-- InstanceBegin template="/Templates/Themes/210TemplateSmall_fw_theme.dwt.php" codeOutsideHTMLIsLocked="false" -->
<head>
<!-- InstanceBeginEditable name="doctitle" -->title of this page<!-- InstanceEndEditable -->
<!-- InstanceBeginEditable name="head" --><!-- InstanceEndEditable -->
</head>
<body>
<!-- InstanceBeginEditable name="contentRegion" -->Some Roster Content goes here<!-- InstanceEndEditable -->
</body>
<!-- InstanceEnd --></html>
if(isset($WA_Roster_1285970700029_Template)){
$WA_Roster_1285970700029_Content->Initialize();
$WA_Roster_1285970700029_Template->ReplaceTemplateRegions($WA_Roster_1285970700029_Content);
print($WA_Roster_1285970700029_Template->Content);
and the original DW template:
require_once( "../webassist/framework/library.php" );
require_once( "../webassist/framework/framework.php" );
?><?php
if("" == ""){
$WA_header_1285963835918 = new WA_Include("../includes/header.php");
require($WA_header_1285963835918->BaseName);
$WA_header_1285963835918->Initialize(true);
if("" == ""){
$WA_vertNav_1285963879008 = new WA_Include("../vertNav.php");
require($WA_vertNav_1285963879008->BaseName);
$WA_vertNav_1285963879008->Initialize(true);
?><!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
<title>Untitled Document 123</title>
<link href="../styles/SGD2010.css" rel="stylesheet" type="text/css" />
<?php echo((isset($WA_header_1285963835918))?$WA_header_1285963835918->Head:"") ?><?php echo((isset($WA_vertNav_1285963879008))?$WA_vertNav_1285963879008->Head:"") ?>
</head>
<body>
<div id="outerWrapperSmall">
<div id="contentWrapper">
<?php echo((isset($WA_header_1285963835918))?$WA_header_1285963835918->Body:"") ?>
<div id="contentSmall"><!-- TemplateBeginEditable name="contentRegion" -->contentRegion<!-- TemplateEndEditable --> </div>
<div id="vert-panel"><?php echo((isset($WA_vertNav_1285963879008))?$WA_vertNav_1285963879008->Body:"") ?> </div>
</div>
</div>
</body>
</html>
I've not even added any dynamic php values...
Some loop?
Plugin Includes should not have been assigned to the parent template prior to converting to a Theme?
Steve
One more post...
Full error (less actual server location):
Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 40961 bytes) in E:\Websites\mysite\htdocs\webassist\framework\framework.php on line 32
and content from line 32:
ob_start();
I've opened up a support incident so that we can look into this with you directly. Someone will call you on Monday. Please update the incident with good times to contact you.
Steve
Hello Ray,
8am - 4pm Pacific are basic working hours.
Steve
Tested from another computer and same problems. But, possibly this is the problem;
I noted in the DW fie bar on the page that is using the theme that it looks to be looking for the same page as is themed. For instance:
$WA_testFW_1286035464517_Template = new WA_Include("Templates{$WA_testFW_1286035464517_Content_Empty}/testFW.php");
"testFW.php" is the same name as the page that is themed... Plus it's looking for a file that does not exist on that path.
A change to target the original template makes my test page now load:
$WA_testFW_1286035464517_Template = new WA_Include("Templates/testTemplate.dwt.php");
I've yet to test the pages created yesterday on my laptop but that is the next step...
Steve
Hello,
I never got a call on Monday...
Also how about Security Assist and it not refreshing to allow selecting values accept every 4th or fifth time? Seems like an obvious bug that renders the key component virtually useless on the Mac unless you hand code the thing...
Steve
Did a couple more tests after removing the dat file and restarting the computer.
Problems still exist.
If Themes -> Create Page with Theme
The primary file linked is itself. For instance if you create a new page using this method the initial values are :
if("" == ""){
$WA_testphpFW_1286405603037_Content_Empty = "";
$WA_testphpFW_1286405603037_Content = new WA_Include(__FILE__);
$WA_testphpFW_1286405603037_Template = new WA_Include("../Templates{$WA_testphpFW_1286405603037_Content_Empty}/untitled_1.php");
require($WA_testphpFW_1286405603037_Template->BaseName);
$WA_testphpFW_1286405603037_Template->Initialize(true);
since "untitled_1.php" is the default name of the new page created.
Next you can take an existing page that you want to theme with the Framework.
Create simple page, apply the original DW template and you get this:
if("" == ""){
$WA_testphpFW_1286405603037_Template = new WA_Include("../Templates{$WA_testphpFW_1286405603037_Content_Empty}/testphpFW");
WA_Include("../Templates{$WA_testphpFW_1286405603037_Content_Empty}/testphpFW)
rather than the correct:
WA_Include("../Templates{$WA_testphpFW_1286405603037_Content_Empty}/testphpFW.dwt.php");
I will make sure one of our engineers calls you today to look into the problem.
Dave BuchholzBeta Tester
I have also now encountered this error whilst testing on my local development server, full error message is: Fatal error: Allowed memory size of 33554432 bytes exhausted (tried to allocate 40961 bytes) in /Users/davebuchholz/Sites/abc-widgets/webassist/framework/framework.php on line 32 which is ob_start();
Everything works fine when including pages with static content one level down from the root.
I have attached the pages that are failing which are situated in a folder called _plugins in the root of the site. These pages are called from the index page whose stripped down code looks like this:
require_once(
require_once('_inc/application.php'); ?>
// Database Query Using parameters
$param1_rsCategoryURL = "-1";
if (isset(
$pathInfo[0])) {
$param1_rsCategoryURL = (get_magic_quotes_gpc()) ? $pathInfo[0] : addslashes($pathInfo[0]);
mysql_select_db($database_connDB, $connDB);
$query_rsCategoryURL = sprintf("SELECT url FROM tbl_categories WHERE url = %s", GetSQLValueString($param1_rsCategoryURL, "text")); // possible values from the GetSQLValueString Function are text, long, int, double, date, defined
$rsCategoryURL = mysql_query($query_rsCategoryURL, $connDB) or die(mysql_error());
$row_rsCategoryURL = mysql_fetch_assoc($rsCategoryURL);
$totalRows_rsCategoryURL = mysql_num_rows($rsCategoryURL);
if(!($totalRows_rsCategoryURL == 0)){
$WA_category_page_1 = new WA_Include("_plugins/category-pages/category-page.php");
    require(
$WA_category_page_1->BaseName);
$WA_category_page_1->Initialize(true);
if($totalRows_rsCategoryURL == 0){
    if(
true){
// WebAssist Framework Builder Dynamic Plug-in: $WA_page_1
switch(isset($pathInfo[0])?$pathInfo[0]:""){ // this could be controlled by a recordset repeat region to cope with expansion
case "about":
$WA_page_1 = new WA_Include("_plugins/about-us-pages/about-us.php");
                break;
            case
"contact":
$WA_page_1 = new WA_Include("_plugins/contact-pages/contact-us.php");
                break;
            case
"legal":
$WA_page_1 = new WA_Include("_plugins/legal-pages/legal-page.php");
                break;
            case
$WA_page_1 = new WA_Include("_plugins/home-page/home.php");
                break;
            case
"index.php":
                break;
            default:
$WA_page_1 = new WA_Include("_plugins/error-pages/page-not-found.php");
                break;
        if(isset(
$WA_page_1)){
            require(
$WA_page_1->BaseName);
$WA_page_1->Initialize(true);
// End: WebAssist Framework Builder Dynamic Plug-in: $WA_page_1
<html xmlns="http://www.w3.org/1999/xhtml"><!-- InstanceBegin template="/Templates/public.dwt.php" codeOutsideHTMLIsLocked="false" -->
<head>
<title><?php echo((isset($WA_page_1))?$WA_page_1->Title:"") ?><?php echo((isset($WA_category_page_1))?$WA_category_page_1->Title:"") ?></title>
</head>
<body>
<!-- InstanceBeginEditable name="mainContent" -->
<?php echo((isset($WA_page_1))?$WA_page_1->Body:"") ?>
echo((isset($WA_category_page_1))?$WA_category_page_1->Body:"") ?>
new dBug(get_defined_vars()); ?>
</body>
// free all memory associated with rsCategoryURL
mysql_free_result($rsCategoryURL);
