Shipping rules based on weight
Thread begun 10/28/2010 5:09 pm by phil107723 | Last modified 11/15/2010 7:54 am by Jason Byrnes | 6831 views | 16 replies |
phil107723
What I am tring to do is:
If total weight is less than 1kg or less for 1item then shipping is five dollars but if total weight of items more than 1kg but less than 3kg 7.50 and if weight is equal or greater than 3kg then shipping is 8.5
I was trying with 3 seperate rules but I got undefined variables errors
I need professional help
On the shipping tab, create 3 rules:
1) Less than 1kg:
Triggers:
SubTotal For Any Column
If the subtotal of column [TotalWeight] is [<] a value of [1]
calculations:
Flat rate of 5
2) Greater than 1kg Less Than 3kg:
Triggers:
If the subtotal of column [TotalWeight] is [>=] a value of [1]
AND
If the subtotal of column [TotalWeight] is [<=] a value of [3]
calculations:
Flat rate of 7.5
3) Greater than 3kg:
Triggers:
If the subtotal of column [TotalWeight] is [>] a value of [3]
calculations:
Flat rate of 8.5
phil107723
Thanks but I've an extra complication
Thanks for that. What's great is the speed of your help and I wasn't that far off on my own. Just to complicate it though I now need to change the cost based on location.
The first location will be just as with the rules but I need to add an extra different cost for each of the rules for the different location.
Now I was thinking somewhere in the shopping cart I would need to have a select location A and would keep the normal rules or select location B which would add the increase to each rule.
Phil
Can you give a little more detail please.
is there going to be a separate cost for each country? or 2 separate fess, one for inside the US and one for outside the US (or other country).
The best way to do this depends on the number of separate possibilities.
if there are only two separate possibilities, we will create 6 different rules, but if there are more, this becomes unwieldy, so we would store the rate in a session.
phil107723
More details on shipping costs
Rule: Less than 1kg
Cost for Location A and Location B is $5
Rule: Greater than 1kg less than 3kg
Cost for location A is $7.50 but cost for Location B is 8.50
Rule: Greater than 3kg
Cost for location A is $8.50 but cost for location B is 22.50
What Exactly is location a? A Country? US? UK? Other? OR a City? Boston? Los Angeles?
What Exactly is location b? A Country? Outside US? Outside UK? Other? OR a City? Outside Boston? Outside Los Angeles?
phil107723
Location A LocationB
Sorry I didn't realise you needed it to be that specific. LocationA is the North Island of New Zealand and Location B is the South Island of New Zealand
Ok, thanks for the clarification. Are those choices in the shipping address on the checkout page?
eCart will store the selected shipping country in a a session variable named:
eCartCheckoutForm_shipping_country
you can use this session variable as a trigger. if the value for Nort New Zeland is "NNZ" and South New Zealand is "SNZ":
you can add triggers to the shipping rules:
Based on Session Variable value:
If the session Variable "eCartCheckoutForm_shipping_country" has a value of "NNZ"
For the south island:
If the session Variable "eCartCheckoutForm_shipping_country" has a value of "SNZ"
phil107723
How to include Session variable
Hi
I'm pretty new at session variables but would I include something like this to my check out page?
<select name='eCartCheckoutForm_shipping_country' >
<option value='NNZ' selected >North Island</option>
<option value='SNZ' >South Island</option>
</select>
And if so would I have to include an update buttton to update the total?
Phil
no, the session will get created when the checkout page posts to the confirm page.
