PS4 Advance options issue
Thread begun 11/04/2010 12:08 pm by lazyhoofer376912 | Last modified 11/16/2010 1:14 pm by Jason Byrnes | 5205 views | 17 replies |
lazyhoofer376912Beta Tester
Im finding myself stuck in this issues with advance options in PS4, the advance option is "color" it is set to black and when i get to the page the product is there..... when i switch it to select another option like "red" the image is not found and the price is "$.00".... if i try to switch back to black i get the same result.
How would i go about resolving this issue?
can you post a link where i could see the issue.
products_detail.php?ProductID=1
it looks like the webassist/plugins/shopping_cart/products_lookup.php file is not uploaded to the server.
make sure the entire webassist directory gets uploaded.
Nope, just doubled checked, and it is on the server. Any other ideas?
OK, if i browse to that page directly,:
products_lookup.php?GroupingID=1&Options=19
it gives a 500 error. this is not a very helpful error for determining the issue.
Try adding the following code at line 1 of that page to turn error reporting on:
error_reporting
(E_ALL);
That didnt help nothing had showed up,.... i placed it on the products_detail.php page,..... i have no clue how to fix this issue.
There should be more information about the error in the servers error log, contact your hosting provider to have them look into the error log, once we know what the error is, we will be able to begin troubleshooting the cause.
Hey jason here is the error...
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/idefine/public_html/love146/products_detail.php:6) in /home/idefine/public_html/love146/WA_SecurityAssist/Helper_PHP.php on line 5
the headers already sent error because of blank space or other output between closing php tags "?>" and opening php tags "<?php"
this output can be a blank line:
or a blank space at the end of the closing tag:
or a comment:
<!-- html comment here -->
the error is reporting the output at line 5 or 6:
if you are not able to spot the issue, send a copy of the php page in a zip archive.
