praise
Thread begun 11/09/2010 2:10 am by i.edwards384429 | Last modified 11/10/2010 11:23 pm by John Langer | 2087 views | 3 replies |
i.edwards384429
praise
Love the new extension works very well.
Had to edit my pages using a search and find because my exisiting connection file had the name conn_localhost.php but apart from that no probs
thanks
Ian
John LangerBeta Tester
Just for future reference. If you have an existing connection, rename it (conn_localhostOLD.php for example) and then make the new dynamic connection file calling it by the same name (conn_localhost.php).
That way no search and replace throughout the site is necessary.
HTH for any future mods.
i.edwards384429
update
Yes hadn't thought of that
Ian
Just for clarity for others who may read this.
If you just create the new Dynamic Connection and call it the same name as the existing one then it overwrites it and works just fine. I only say rename the existing connection in case it goes pear shaped. Then at least you still have the original connection to fall back on.
