Adding 3 lots of the same item to shopping cart causes a problem
Thread began 11/09/2010 2:03 pm by phil107723 | Last modified 11/22/2010 6:18 am by Jason Byrnes | 1862 views | 5 replies |
phil107723
When I add 3 lots of the same item to shopping cart the first 2 are okay and it just adds them together. But when I add a third of the same item it creates it on a new line as if it is a different product. This error doesn't happen if I change the quantity in the shopping cart and click the update button.
I just checked another website for the same problem and it has the same issue.
can you send a link where I can see the problem and a copy of the eCart object file so i can examine the code.
phil107723
Link to test site product.php?pKey=54 and a copy of ecart object attached.
eCart1_PHP.zip
in the cart object, you have set the Quantity Column to be Unique.
Uncheck the unique option for the quantity column to correct the issue.
phil107723
Thanks for the help
You're welcome.
