Dynamic DD menu - third level problem
Thread begun 11/10/2010 10:18 pm by superpac250441 | Last modified 11/15/2010 7:22 am by Jason Byrnes | 4030 views | 6 replies |
superpac250441
Hi there,
I am trying to build a dynamic third level on one of the drop downs (products). I can do this quite successfully until I try building the next menu item to drop down from next top level item. The menu then breaks up. I have attached the menu page and the cssmenuwriter folder. Can anyone give me a clue as to what is causing this problem.
Many thanks
can you send a link where i can see the issue in the browser.
Looking at the code, i don't see a problem.
superpac250441
Many thanks
YOU CAN SEE IT AT MenuTest.php
It give the following error:
Parse error: syntax error, unexpected '=' in /home/agricon/public_html/b/CSSMenuWriter/cssmw2/menu.php on line 109
Line 109 onwards:
<?phclass="level-3">
<?php if ($totalRows_menuwriter_productsubcategory > 0) { // Show if recordset not empty ?>
<?php do { ?>
<li><a href="<?php echo($assumedRoot); ?>plugins/<?php echo $row_menuwriter_productsubcategory["url"]; ?>"><?php echo $row_menuwriter_productsubcategory["Name"]; ?></a></li>
<?php } while ($row_menuwriter_productsubcategory = mysql_fetch_assoc($menuwriter_productsubcategory)); ?>
<?php } // Show if recordset not empty ?>
</ul>
The snagged picture attached shows what it looks like on my local host
ahhh, the error helps a lot.
change 109:
<ul class="level-3">
superpac250441
This post has been deleted.
superpac250441
Another problem
Hi there,
It worked on my local host but not for some reason at the hosting server. So I rebuilt is, cleaned out the free mysql's out of menu.php inside the menuwriter folder but still get an error:
Parse error: syntax error, unexpected '<', expecting T_VARIABLE or '$' in /home/agricon/public_html/b/CSSMenuWriter/cssmw/menu.php on line 135
It can be seen at menu.php
Any assistance is much appreciated
superpac250441
Hi again,
It's not writing the code correctly but I have sorted out the problem - so many thanks
OK, glad to hear you have found the problem.
