Light box not showing
Thread began 12/06/2010 9:54 am by balexander389215 | Last modified 12/08/2010 2:44 pm by Dani Chankhour | 2159 views | 5 replies |
balexander389215
I've been trying to get Power Gallery working. I added it to a site following all directions and everything checks out okay. The URL works fine:
addtosite.php
however when I go to the menu I do not get the lightbox showing up just all the images in one long list.
gojukangallery.php
I've removed and reinstalled a couple of times in different locations to see if it would make a difference but no luck. (On a side note I discovered I had to clear all my activations to reinstall this product. You'd think people smart enough to create all these products could set it up to clear activations on only one product at a time.)
I embedded the script that was given in the page
$pg_id = '1';
$pg_theme = 'light';
include('/home2/brianda4/public_html/gojukan/gojukangallery/galleries/ribbon_fullsize/index.php');
Any ideas on where to go from here.
Dani Chankhour
This post include a file that should fix the issue you are having:
showpost.php?p=81968&postcount=5
balexander389215
That did the job, thank you. Now I see that the images are too big for the available space and the next and last tabs do not appear. Do I have to resize all the images manually or is there a configuration option to correct this?
Thanks again.
Dani Chankhour
Yeah, the outerWrapper is too small to fit the gallery.
You need to increase the width of the outerWrapper, however this might require other adjustment to the layout.
to do this open the content.css in the siteassistpro_css folder and change the outerWrapper width from 760px to 1024px.
This will fix the gallery issue, but this might cause other issues to the layout.
balexander389215
Can the gallery itself not be re-sized to fit a 760 wrapper? You are correct that trying to change the outterwrapper size leads to a whole set of new problems. I tried resizing the images as per another post, going to admin_gallery/common/properties.php and changing the 1024 array size to a 680x420 size and then changing the watermark to force a re-size but this had no effect. The images did not re-size. I must be misunderstanding the process. Considering your sitebuilder uses a 760 outterwrapper size it would make sense that the gallery could fit in this framework.
Dani Chankhour
we can try adjusting the outerWrapper of the gallery.
In the galleries folder open the index.php page for the gallery that you are using.
On the top of the page, there should be a line that look similar to this:
#pgOuterWrapper { width: 895px; margin: 20px auto; }
try changing the width to 760 or less.
