Array in Variable
Thread began 2/03/2011 6:58 am by swolock397582 | Last modified 2/03/2011 7:57 am by Jason Byrnes | 1253 views | 3 replies |
swolock397582
Array in Variable
I would like to be able to echo some text that looks like this 'i1, i2, i3, i6, i8' where the numbers are unique IDs from a table. It seems to me I could do this with an array but I haven't been able to get it to work.
Ideally I could use the variable wherever I want on a PHP page like 'echo $thearray;'
Any ideas or help are greatly appreciated?
PS... I'm wondering if there's a way to use Create Dynamic Array from Dynamic Dropdowns.
create a recordset to return the ids, then create the array using code similar to:
$myArray
= array();
do {
$myArray[] = "i".$row_RecordsetName['ID'];
} while (
$row_RecordsetName mysql_fetch_assoc($RecordsetName));
you will need to replace "RecordsetName" with the name of the recordset and ID with the name of the ID column.
convert the array to a comma separated list using this:
<?php echo(implode(", ",$myArray)); ?>
swolock397582
Wow! Thanks for the amazingly quick response and simple solution. It works perfectly.
you're welcome.
