Arguments are of the wrong type, are out of acceptable range, or are in conflict ...
Thread begun 2/08/2011 5:59 pm by suarezm129397438 | Last modified 2/14/2011 2:30 pm by Jason Byrnes | 13789 views | 7 replies |
suarezm129397438
I'm getting the following error when I try to test my log in page:
ADODB.Command (0x800A0BB9)
Arguments are of the wrong type, are out of acceptable range, or are in conflict with one another.
/mstest1/WA_SecurityAssist/Helper_JS.asp, line 15
I have gone through the turial, and have tried to set up the log in pages several times and still get the same error. Attched is a zip file containing the login, log out pages along with the WA_SecurityAssist folder containing the applicable *_JS.asp pages. Help!
Line 15 is looking at the database connection
How is your connection defined?
Are you using MS SQL Server or an MS Access Database?
Can you send a copy of the Connections/thscData.asp file.
one thing that jumps out at me is line 9:
WA_Auth_Parameter.tableName = "null.admin";
Is "null" the name of your database?
This is a reserved word in the SQL language and should be avoided when naming database objects.
suarezm129397438
I set up a OLE DB virtual connection. This is the connections string:
"Provider=Microsoft.ACE.OLEDB.12.0;Data Source=" & Server.MapPath("\mstest1\data\thscData.accdb")
I'm using an access database (MS 2007)
I've attached the connections file thscData.asp
The name of the database is:
thscData.accdb
The table with the id/pw info is called:
admin
I did notice that the database pannel in Dreamweaver (CS4) the table names and views have "null." preceding each of the names.
Thanks for your help.
are you testing the page locally or remotely?
If you are testing remotely, you may not be able to use the Microsoft.ACE.OLEDB.12.0 provider in the connection string. you may need to use Microsoft.Jet.OLEDB.4.0 as the provider.
also, check that the Server.MapPath function is actually locating the database. create a blank ASP JS Page, and add the following code to double check it:
DB Path: <%=Server.MapPath("\\mstest1\\data\\thscData.accdb")%>
suarezm129397438
I was able to get it to work testing locally using the following OLE DB connection string:
"Provider=Microsoft.ACE.OLEDB.12.0;Data Source=C:\Inetpub\wwwroot\mstest1\data\thscData.accdb;Persist Security Info=False;"
However it still does not work on the server.
I checked the path as you suggested and this is what came back.
When I run it locally I get:
DB Path: c:\inetpub\wwwroot\mstest1\data\thscData.accdb
When I run it on the server I get:
\\10.0.40.33\mstest1.com\public\mstest1\data\thscData.accdb
I think the correct path to the database on the server is:
\\10.0.40.33\mstest1.com\public\data\thscData.accdb
I've tried severl different things and I still cannot get the connection to work on the server.
have tried hard coding the path:
\\10.0.40.33\mstest1.com\public\mstest1\data\thscD ata.accdb
in the connection string:
Data Source=\\10.0.40.33\mstest1.com\public\mstest1\data\thscData.accdb
or if you think \\10.0.40.33\mstest1.com\public\data\thscData.accdb is the coorect path try using that:
Data Source=\\10.0.40.33\mstest1.com\public\data\thscData.accdb
the server may not have the Microsoft.ACE.OLEDB.12.0 available, like i said before, so you may need to change the provider to use the Microsoft.Jet.OLEDB.4.0 provider instead.
suarezm129397438
I finally got it to work on the server using the following connection string:
"Provider=Microsoft.ACE.OLEDB.12.0;Data Source=\\10.0.40.33\mstest1.com\public\data\thscData.accdb;Persist Security Info=False;"
The problem that I was having was because when I test locally I use this connection string:
and I was not switching to the server connection string prior to testing on the server. My question is:
Is there a way to automate which connectin string is used depending on where program is being used (local vs server)? Or do I have to manually switch back and forth between these two connection strings?
For asp, no, there is not a way to automate which is used.
For PHP we offer a Dynamic Connection extension for this.
For ASP, i recommend changing the connection to use the remote connection string, uploading it to the server, then changing the permissions on the connections file on the remote server to read only. This way, when you revert the connection to the local connection string, Dreamweaver will fail if it tries to over write the one on the server.
