Trying to fudge some code!! :)
Thread begun 2/15/2011 12:39 pm by iamdan356160 | Last modified 2/22/2011 10:03 am by Jason Byrnes | 7381 views | 15 replies |
iamdan356160
Hi all,
I'm not a PHP expert in any shape or form... mainly find myself guessing my way thru stuff (due to the fact that you can with the help of WebAssist plugins :)...
Anyway... got this line of code in my script...
$query_rs_discountdetails = "SELECT * FROM Discounts WHERE disc_code = $row_WADAUsers['User_DiscCode']";
which is causing a syntax error. Im trying to get the SQL statement to use a binding from another recordset. Any ideas on how to get this to work??
Regards,
Dan
correct syntax would be:
$query_rs_discountdetails = "SELECT * FROM Discounts WHERE disc_code = ". $row_WADAUsers['User_DiscCode'];
make sure that the rs_discountdetails code is on the page before it is used in this query.
iamdan356160
Hi Jason,
Thank you for the quick reply... this sorted the syntax error... But, I've not been able to actually achieve my desired goal... maybe you could help with that?...
I've built a list / results page, using DataAssist... I've added some icons into the list, with a cool tooltip that displays more details. Each record in the list is a record from the "Users" table, and contains a field called 'User_DiscCode'. I also have a table called 'Discounts' that contains a field called 'disc_code'. I basically want to be able to display the Discount info (from the 'discount' table) in the tool tip, if 'disc_code' matches the users 'User_DiscCode'. How could I this and make it work for all records in the list?
Does that make sense?
Edit the main WADAUsers recordset for the page to use a join query to get the related data from the Discounts table:
SELECT Users.*, Discounts.disc_code
FROM Users
INNER JOIN Discounts
ON Users.User_DiscCode = Discounts.disc_code
This code will go in place of the SELECT ... FROM portion of the recordset, if there is a where clause, or order by clause, leave that in place untouched
this way the related disc_code will be returned for each record.
iamdan356160
Hi Jason,
Thanks for the reply... Two things though...
1. I've added your code... but now the list is only showing users that have used a discount code!?
2. Where can I find the bindings that the 'INNER JOIN' would have brought in?
Thanks in advance! :)
Dan
try using LEFT JOIN then
the binding for the nee column returned from the reocrdset should be on the Bindings panel.
iamdan356160
Hi Jason,
The LEFT JOIN has appeared to work (All users appear in the list now).
But I'm not getting the 'Discount' table details in the bindings panel!?
What PHP would I need to type, to get the fields to appear in the list?
Thanks in advance,
Dan
close Dreamweaver, then open the Windows Explorer or Macintosh Finder. Browse to the location of your Dreamweaver site files, and delete the _mmServerScripts folder.
iamdan356160
Hi Jason,
I've tried that, but I'm still getting the same issue. I still can't see the bindings for the discounts table... I've attached a screenshot. Have I got the SQL statement correct? Is there anything else that could be causing this?
Dan
the bindings will be under the WADAUsers recordset.
Expand that recordset to find the binding for the Discounts.disc_code column.
