Restrict access to a page using rules manager
Thread begun 2/17/2011 2:01 pm by mora398588 | Last modified 2/17/2011 2:12 pm by Jason Byrnes | 1843 views | 1 replies |
mora398588
* Please see attached files.
I am attempting to restrict access to my pegforms.php page using SecurityAssist. However, I still want the ability to have people access it using a password only.
I am a bit perplexed on how to set up a rule using rules manager to allow those with the correct password to access the pegforms page while keeping unwanted people out.
I have setup an sql database containing an ID and a password column with pre-set passwords already inserted. The individual accessing the protected page would be issued one of the pre-set passwords to access the protected page.
The pegaccess.php file is the log in page for this.
your login page is not using the security assist login functions, it is using the Dreamweaver login, if you are going to use the Dreamweaver login, then use the Dreamweaver restrict access to page behavior instead of the security Assist behavior (Insert -> Data Objects -> User Authentication -> Restrict Access to Page)
