Australian Currency in Ecart 5!
Thread begun 2/21/2011 8:18 pm by help_info383092 | Last modified 2/28/2011 6:31 am by Jason Byrnes | 4020 views | 7 replies |
help_info383092
I can not specify Australian dollars symbol in the custom currency field. I type $AUD in the field and it came up with error!
Anyone having the same problem!
Regards,
Eric
in the eCart object enter the currency symbol using a forward slash to escape the dollar symbol:
\$AUD
help_info383092
Back Slash for Australia Dollar - /20.00 \20!
The back and forward do not work on Ecart Object on Australia dollar. I have tried to pur $/AUD and \$AUD it came up with this: /20 and \20. Everythign is workind perfectly except the Australia dollar symbol. Is there any way to edit in the code?
Below is the error:
Notice: Undefined variable: AUD in C:\wamp\www\Ramelau\WA_eCart\pbook_PHP.php on line 250
Regards,
Eric
it worked on my system when i used:
\$AUD
can you send a copy of the WA_eCart\pbook_PHP.php file so i can have a look at the code.
help_info383092
\$AUD came up with \20
Please find attached is the code! On the PayPal payment window still $26.00 USD. On the cart.php and confirm.php came up with \20 and \26 with the following error:
Call Stack
# Time Memory Function Location
1 0.0021 537224 {main}( ) ..\confirm.php:0
2 0.0037 685752 require_once( 'C:\wamp\www\Ramelau\WA_eCart\pbook_PHP.php' ) ..\confirm.php:3
Call Stack
1 0.0008 386824 {main}( ) ..\phrasedbook.php:0
2 0.0032 535352 require_once( 'C:\wamp\www\Ramelau\WA_eCart\pbook_PHP.php' ) ..\phrasedbook.php:3
change line 250:
$pbook = new pbook_Definition("pbook", 0, "\\$AUD", "", true, 2, 0, "oz", true, 2, 1, 0);
$pbook = new pbook_Definition("pbook", 0, "\$AUD", "", true, 2, 0, "oz", true, 2, 1, 0);
to change the currency code sent to payapl, you will need to edit the code that sends the transaction to them.
if you are using paypal payments pro, the confirm page will have this code:
$PP_PayPro_optional[0][$nextIndex] = "CURRENCY";
  $PP_PayPro_optional[1][$nextIndex] = "USD";
change it to:
  $PP_PayPro_optional[1][$nextIndex] = "AUD";
if it is paypal standard, change:
<input type="hidden" name="currency_code" id="currency_code" value="USD" />
help_info383092
AUD Currency!
Hi Jason
Thank you for your help! It works now.
you're welcome.
