"initializeUI" and "uiClose" not defined
Thread begun 2/26/2011 4:28 pm by chasmichaelp422603 | Last modified 8/19/2013 8:20 am by Jason Byrnes | 3952 views | 3 replies |
chasmichaelp422603
I have installed CssFormbuilder2 and everytime I try to use it I get nothing but the following message.
Dreamweaver
While executing onLoad in WAFB_AddForm.htm, the following
JavaScript error﴾s﴿ occurred:
In file "WAFB_AddForm":
initializeUI is not defined
When I close the message window I get this message:
Dreamweaver
O While executing onUnload in WAFB_AddForm.htm, the following
uiClose is not defined
So I have tried to remove CSSForm2 and Form Tool1 to start all over again and after hours of running the Adobe extension installer is still spinning its little dial saying that it is uninstalling form tool 1.0. How many days should this take?
PS I have not installed the HTML editor at all.
This sounds like a dreamweaver cache issue.
1) Close Dreamweaver
2) go to %appdata%/adobe/dreamweaver version/en_us/Configuration
3) delete the file named winfilecache_[random number].dat
Then open dreamweaver and try to use the extension. This is almost always the solution when you see the error:
"initializeUI is not defined"
Colin
Same problem but on a Mac
I have the exact same problem, but on a Mac... Mac OSX Mountain Lion, running Dreamweaver CC.
Thanks...
Delete the Dreamweaver Cache file from the users configuration folder:
http://www.webassist.com/community/tutorials/view_tutorial.php?tid=95
