Gallery fails to load
Can anyone help I have uploaded images to the gallery through the admin panel, but when I preview the gallery all images are failing to load:
index.php?gallery=1&theme=dark
here are updated copies of the following files:
galleries/global.php
webassist/framework/library.php
that should correct the issue.
Hi Jason,
Uploded files and now seeing this on the page:
index.php?gallery=1&theme=dark#
Thanks James,
I will refer to the support ticket.
