universal email not to edit
Thread begun 3/12/2011 4:45 am by Cologne | Last modified 4/29/2011 12:27 pm by Jason Byrnes | 5959 views | 13 replies |
Cologne
hi,
I use ecart and now I wanted to edit the email that is sent with ecart. When I doubleclick on the server behavior "universal email" nothing happens.
I use "CSS Form Builder 2", too.
How can I edit the email?
Denis
Delete the Dreamweaver Cache file from the users configuration folder:
If you are still having troubles, send a screen shot showing the extensions you have installed.
Cologne
Hi Jason,
it still dont work :-( I double click on it, the sandbox shows up. then nothing happens.
Here are the files.
Denis
I dont understand what you mean by the sand box shows up, can you provide more details.
Cologne
Hi Jason,
I cant re-edit the universal email server behavior.
When I double click on the universal server behavior - "nothing happens"
It does not open, so i can make chnges etc.
thats it.
Denis
In your screen shoot, you have hidden some of the installed extensions.
it could be that one of your other extensions is causing a conflict with Universal Email. try following step 12 in the adobe troubleshooting doc:
kb405604.html
then reinstalling CSS Form builder.
Cologne
Hi Jason,
when I do that I have to reinstall all my extensions!
Whats wrong with that extension? How can I edit the Universam Email in eCart without installing everything new.
cheers!
have you tried uninstalling CSS Form builder and then reinstalling it?
If that does not work, I suspect that there is corruption in the configuration folder which means that you will need to rename the configuration folder as previously suggested.
Cologne
Hi Jason,
it still does not work.
I deinstalled eCart, Formbuilder. It wont work, the eMAIL is not sent, and I even cant reEdit the email.
When I click on the Email Binding in the server bahavior nothing happens :-(
Cheers
Denis
have you tried renaming the configuration folder?
It sounds like there is corruption in the configuration folder to me.
