Custom Shipping from database
Thread begun 3/25/2011 11:41 am by bjgarner241692 | Last modified 3/25/2011 1:21 pm by bjgarner241692 | 2846 views | 6 replies |
bjgarner241692
I've setup country and state / province in my db with a shipping premium so that they each have a base rate for orders to that region.
I started with a simple Flat Rate amount to get it working initially. That's all fine.
Now I want to substitute my flat rate of .02 with the value from the db.
//eCart Rule
function WAEC_eCart1_Country()  {
  $totalShipping = 0;
  if (true && ((sizeof($this->Items) > 0) && (isset($_SESSION['eCartCheckoutForm_country'])))) {
    $totalShipping +=  '".$row_shipcountry['ShipPremium']."';//Result
  return WA_eCart_FormatNumber($totalShipping, $this->ForceDecimalsC, $this->DecimalPlacesC);
//eCart Rule
This is in eCart1.php
Recordset shipcountry is on confirm.php. Session values and Recordset works fine.
My problem is syntax.
I get:
Parse error: syntax error, unexpected T_STRING in C:\Inetpub\vhosts\drjacknewman.com\httpdocs\2011\WA_eCart\eCart1_PHP.php on line 99
Line 99 is of course the line that includes:
i have also tried <?php echo $row_shipcountry['ShipPremium']; ?> with a similar type of error.
Please help if you can.
Thanks,
change:
$totalShipping += "".$row_shipcountry['ShipPremium']."";//Result
bjgarner241692
Thank you.
That eliminated my error, but the amount is not being added to my shipping value so I still have some work to do.
I've placed the premiums on the page so that I can see that they are correct so that's not it.
Perhaps I should be doing this with the calculations tab.
try storing the ShipPremium amount from the recordset into a session variable and using the session variable value in the charge rule instead of the recordset value.
bjgarner241692
OK,
So I setup the Session Value on the confirm page, trigger is if rs is not empty.
then I changed the shipping calc to this on eCart1.php
//eCart Rule
  $totalShipping = 0;
$totalShipping += "".$SESSION['shipcountry']."";//Result
//eCart Rule
No errors. Session Values are correct, but still no shipping amount.
Seems like it is still a Syntax issue, in getting that value to register as a number.
bjgarner241692
Since I now have the number I need in a Session Value I simplified the shipping rule to:
//eCart Rule
  $totalShipping = 0;
  if (true && ((sizeof($this->Items) > 0) && ((isset($_SESSION['shipcountry'])?$_SESSION['shipcountry']:"") > "0"))) {
//eCart Rule
but it still ignores it.
Just to check, I substituted
with 10, and the rule works fine, adding $10.00.
Has to be syntax.
bjgarner241692
This worked.
//eCart Rule
  $totalShipping = 0;
    $totalShipping += $_SESSION['shipcountry'];//Result
//eCart Rule
Thank you for your assistance. Hope this helps someone else.
Key was getting a Session Variable with the number I needed.
