Paypal Payments Pro Canada
It's been a few months now that Paypal Payments Pro for Canada has been available will Ecart be compatible with it soon?...
Ecart is automatically compatible according to our testing. It uses the same exact code, so it should just work.
I think the only change you will need to make is to update USD to CAD. Other than that it should work out of the box. Are you using Simple Checkout, Direct Payment, or Express Checkout with Direct Payment? ASP, CFML, or PHP?
You can probably just do a find and replace for "USD" to "CAD", or if you give me more information I can try to lead you in a more precise direction.
