ecart only shows one iterm
Thread begun 3/30/2011 8:13 am by osvaldo399181 | Last modified 3/30/2011 10:49 am by Jason Byrnes | 4551 views | 9 replies |
osvaldo399181
I have list of items from a dynamic table, there is ItemName ItemDescription ItemPrice. I added a add to cart button, and configured display manager. When I click add to cart it only shows the last item on the shopping cart, it does not create a list. How do I associate ecart to a database?
each item needs to have a unique ID as well.
If the iD is not unique, they will be treated as the same item.
osvaldo399181
ecart Single item
I have a unique ID for the item, this here is some of the code.
// WA eCart AddToCart
if (isset($_POST["eCart1_1_ATC"]) || isset($_POST["eCart1_1_ATC_x"])) {
$ATC_itemID = $_POST["eCart1_1_ID_Add"];
$ATC_AddIfIn = 0;
$ATC_RedirectAfter = "../purchases/OMC_Shoppingcart.php";
$ATC_RedirectIfIn = "";
if (isset($totalRows_Recordset1) && $totalRows_Recordset1 > 0) {
$row_Recordset1 = WAEC_findRecordMySQL($Recordset1, "ORDERID", $ATC_itemID);
if ($row_Recordset1) {
$ATC_itemName = "".$_POST["eCart1_1_NUMBER_Add"] ." of " ;// column binding
$ATC_itemDescription = "".$_POST["eCart1_1_NUMBER_Add"] ."";// column binding
$ATC_itemThumbnail = "";// column binding
$ATC_itemWeight = floatval("0");// column binding
$ATC_itemQuantity = "".$_POST["eCart1_1_Quantity_Add"] ."";// column binding
$ATC_itemPrice = "".$_POST["eCart1_1_Sale_Add"] ."";// column binding
mysql_data_seek($Recordset1, 0);
$row_Recordset1 = mysql_fetch_assoc($Recordset1);
$ATC_itemQuantity = floatval($ATC_itemQuantity);
if (is_numeric($ATC_itemQuantity) && $ATC_itemQuantity != 0) {
$eCart1->AddToCart($ATC_AddIfIn, $ATC_RedirectIfIn, $ATC_itemID, $ATC_itemName, $ATC_itemDescription, $ATC_itemThumbnail, $ATC_itemWeight, $ATC_itemQuantity, $ATC_itemPrice);
if ($ATC_RedirectAfter != "" && $eCart1->redirStr == "") {
$eCart1->redirStr = $ATC_RedirectAfter;
if (isset($_SERVER['QUERY_STRING']) && $_SERVER['QUERY_STRING'] != "") {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF']."?".$_SERVER['QUERY_STRING'];
else {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF'];
<form name="eCart1_1_ATC_<?php echo $row_Recordset1["ORDERID"]; ?>" method="POST" action="<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""; ?>">
<input type="hidden" name="eCart1_1_ID_Add" value="<?php echo $row_Recordset1["ORDERID"]; ?>" >
<input type="hidden" name="eCart1_1_SIZE_Add" value="<?php echo $row_Recordset1["PhotoSize"]; ?>" >
<input type="hidden" name="eCart1_1_NUMBER_Add" value="<?php echo $row_Recordset1["PhotoNumber"]; ?>" >
<input type="hidden" name="eCart1_1_Quantity_Add" value="<?php echo $row_Recordset1['PhotoQty']; ?>" >
<input type="hidden" name="eCart1_1_Sale_Add" value="<?php echo $row_Recordset2['ItemSalePrice']; ?>" >
<input type="image" src="../WA_eCart/Images/Pacifica/Btn5_EN_addtocart.gif" border="0" class="eC_ImageButton" value="Add to Cart" name="eCart1_1_ATC">
</form>
please send a link where i can see the problem.
osvaldo399181
link
user.php
EventID : 61910
email: any
password: 1
after login click on ORDER LIST
when i click on Order list, the order list showsa only one add to cart button.
the add to cart form does not have any values in it when i view the page source:
<form name="eCart1_1_ATC_" method="POST" action="/Clients/csweet15/2010/StephaAmp/OMC_Orders.php">
<input type="hidden" name="eCart1_1_ID_Add" value="" >
<input type="hidden" name="eCart1_1_SIZE_Add" value="" >
<input type="hidden" name="eCart1_1_NUMBER_Add" value="" >
<input type="hidden" name="eCart1_1_Quantity_Add" value="" >
<input type="hidden" name="eCart1_1_Sale_Add" value="" >
<input type="image" src="../../../../WA_eCart/Images/Pacifica/Btn5_EN_addtocart.gif" border="0" class="eC_ImageButton" value="Add to Cart" name="eCart1_1_ATC">
</form>
i'm not able to reproduce the error on this page.
osvaldo399181
please use the email: osvaldo@omcvideo.com
This login has 3 items.
please send a copy of your add to cart page and the cart display page in a zip archive so i can see the code.
osvaldo399181
zip files
Thanks for your help.
this page is very odly set up with the add to cart server behavior code in the body of the page, this will cause the cart redirect not to function.
the add to cart is also getting the values from the recordset1 recordset, but I do not see that defined anywhere.
