Pre Sales Question
Thread begun 4/13/2011 9:04 am by A Sound Design | Last modified 4/13/2011 2:03 pm by Jason Byrnes | 5066 views | 9 replies |
A Sound Design
Pre Sales Question
Hi. I am looking to purchase this extension but need a few answers before I do.
1) Can this be set up so that on a registration page created with it the administrator gets an email notifying them that a new user has registered?
2) Can you create a double opt in?
3) What type of security does it use? MD5, SHA1 etc.
That's all I can think of for now :)
With only the security assist extension, these things are not possible.
1) to send the email to the site administrator, you will need Universal Email as well.
2) to create a double opt in, you will also need DataAssist. See this thread for details on creating a Double opt in using Data assist and universal Email.
3) The encryption method used in security assist is SHA1
A Sound Design
Thanks for the quick reply Jason. Do I have to use Universal Email or will other methods of sending mail work?
I have the CSS Form Builder extension. Can I use the Login and Registration forms in this or will I need to use the ones in SA? For registration I am looking to create a quite detailed form and the one in Form Builder looks good. I just want to use the actual security measures of SA with this form. I like the Captcha in Form Builder so want to use that.
Regarding double opt in I have read that thread. Does this mean that by creating a random password the user will not be able to choose their own at registration or is this just a hidden field that is only for creating a double opt in? Just wanted to clarify this.
If you have CSS Form Builder 2, this includes all of the functionality of Universal Email.
The security assist wizard will not create pages that use Form builder forms for login and registration.
to use form builder forms, you will need to crate the login and registration pages manually. Add the form to the page, then apply the Security Assist Authenticate User behavior for login, or the Insert Record Behavior for the registration.
The random password mentioned in that post does not effect the password that the user enters, it is just a random string that is used to update the users status from the link in the email.
A Sound Design
I have version 1.0.2 of Form Builder, so back to the original question "Do I have to use Universal Email or will other methods of sending mail work?". Unless I upgrade to version 2, of course.
Thanks for clarifying the other points. I just want to know if various other WA products are going to integrate with this but also want to be able to use some of the existing DW extensions that I have from other companies as well.
other methods of sending the email may work, but I cannot say if they will for certain.
the key to double option is this:
on registration, a new record is created in the users table. the verified column is set to 0 and a random string is inserted to the random string column.
an email is sent to the user that just registered with the Primary Key value and random string as querystring variables in a link to the confirm page.
the confirm page uses the querystring variables to update the verified column of the users record.
as long as your other email method allows you to modify the email that is sent and add the link to the confirm page with the ID and Random string, then it should work.
I know that GoDaddys form mailer script instance will not allow this sort of control over the email message. I'm sure there are other methods out there that have the same restriction. I'm also sure there are other methods that will work.
A Sound Design
I was just looking at the details of the SA extension and from one of the screenshots it looks like it could make a more fully featured registration page so I could always use this for registration. On this point, if I upgraded to Form Builder version 2 would the email sending part of it work with the SA extension or would I need the full Universal Email extension too?
The Email Sending function of CSS Form Builder 2 is Universal Email. Universal Email is sold as a separate stand alone product, but also bundled into CSS form Builder 2.
A Sound Design
So if I upgraded to v2 of FB it would be the same as buying UE as well or does it only work in FB????
In terms of the actual registration form that can be created with this, is it limited to a certain amount of fields or could you have as many custom ones as you like? For example, I would like to have all the standard name, email, etc. but also web site, Facebook profile url, avatar image, etc. Can SA do this?
Yes, upgrading to Form Builder 2 would be the same as buying UE.
You can create the registration form with whatever fields you like, you just need to make sure that Users table has corresponding columns to store the information when the user registers.
