Plug from into own design?
Sorry title should have read "Plug form into own design?" (Unable to edit title!)
Is there an easy way to put the registration form into your own website design?
Is the registration form a framework style plugin?
The site is set up with framework style themes and uses framework plugins in a couple of places as well.... so you should be able to adjust the templates or create your own using those common concepts.
